Servo's
Commencé par Maverick
7 répies 13 aimers Dernière activité : il y a 5 ans
Servo's
D these are a few of mine Hi you will find them very good and have loads of power for the rudder and there not expensive I use them on all my boats even it is driving two rudders 👍
Servo's
Servo's
Hi John P, I have fitted one these today for MTB which i bought at the weekend because the one in it did not very good and the wiring was Frayed anyway. I actually bought Two the other one is for the rudder on my Pilot Cutter Katie.
Cheers Jon
j a Easter.
Aimé par Scratchbuilder
Servo's
I agree with the other posts re these small servos. My original RG65 yacht had such a servo and it worked fine for a while until I fitted a 6.6 volt LiFe battery. Used in many other models without problem but it literally melted the rudder servo. I subsequently found out from Servo Shop that the small servos have a max voltage rating about 5v. I fitted a Ubec to reduce the voltage to 5v and another small servo and that has worked without problem. They are well manufactured and mine had metal gears so are as Ron says suitable for small spaces in smaller models.
Aimé par Muskrat and Scratchbuilder
Servo's
Morning Maverick.
I agree with Ron, do not use a micro servo.It will not stand up to the stress and strain.
Most good quality servos as shown in Ron’s picture are good and there are many different types out there.I tend to used brass geared workings as they are more robust,but cost a little more
Re fittings.
Try Caldercraft.
Model boat Mayhem site,there are various outlets mentioned on it.
Cornwall model boats.
to name but three.They are a difficult scale but are out there depending on what you want.
Regards Bill.
Aimé par Muskrat and dave976 and
Servo's
For the control of rudder steering, are one of these micro servos strong enough, or do I need a larger High torque servo please.
Also who's the best supplier of 1/12th scale Boat fittings.
Aimé par dave976
