Sourcing timber
Commencé par flaxbybuck
13 répies 40 aimers Dernière activité : il y a 4 ans
Sourcing timber
Zooma asked where to buy a cooling fan of the type shown in my pictures. I found them on line with a choice of size, and of voltage.
Sourcing timber
In addition to using venetian blind slats for planking the boat I use them for other things such as sanding sticks (glue sandpaper to each side of a 6" length), stirring sticks (cut down to size) stain sampling sticks (to compare different colour wood stains), gangplanks, coamings, the list goes on.
Aimé par dave976 and Colin H
Sourcing timber
I use an alloy water-cooled mount in my boats - but I do like your idea and I will try it.
The power loss from driving the fan should be quite minimal and it would be nice to find a use for all those prop adapters that do not get used.
Where do you buy a fan like that?
Aimé par Colin H and stevedownunder
Sourcing timber
I just noticed the fan for cooling , your motor (Turnigy) will have come with a prop adapter and I used this to mount a fan from a fan assembly similar to the one you have used but on the back end of the motor, works really well.
Aimé par Colin H and flaxbybuck and
Sourcing timber
MY PREVIOUS QUOTE:-
"I have now been advised (thanks Doug) that "lime" wood is actually "pear"."
DOUGS QUOTE :-
Er no!
I said that basswood (as it's mostly known in the US) is called lime in the UK.
Main thing is - that your boat doesn't go pear shaped!
As our antipodean friends might say 😉
Very confusing...and not helped by that gin and "lime"!
- so "pear wood" is known as "pear wood" and "bass wood" is known as "lime wood" - unless it is known as "Linden wood".
I will try to remember that 🤣
Aimé par Colin H and Scratchbuilder
Sourcing timber
Er no!
Sourcing timber
I have just braved the snow and popped out into the garage to check the spacing of the regular oblong shaped "string slots" that are machined into every Venetian blind slat that I have.
The distance between these slots is 16", so I can make one long strip of wood from each side of every slat, and end-up with a lot of 16" lengths from the middle that will be approximately 1" wide .
These 16" lengths could be cut or stripped as required for future projects.
Aimé par Scratchbuilder and Colin H
Sourcing timber
Perhaps when I have made some strips I can use them for stringers
They won't be a flexible or as easy to work with as obechie as it is a harder wood, but it would probably be really good for planking larger hulls like Tony is using it for on his dragon yacht.👍
Aimé par stevedownunder and Scratchbuilder and
Sourcing timber
I think my venetian blind slats are pear wood and look nice.
Maybe I could run them through the bandsaw to make long strips from both sides?
Most of the wood (from the middle of the slates) would then convert itself into shorter lengths as I hit the regular string slots.
Its a shame to waste so much of the wood - but I should get plenty of 1/4" wide strips and lots of short lengths to make other things from in the future!
Aimé par dave976 and stevedownunder and
Sourcing timber
Hi, I used venetian window slats to plank my dragon yacht which is still in build, highly recommended!
Tony A........
Tony A.....
Aimé par jimdogge and dave976 and
Sourcing timber
That's a great idea, there are always some at our local recycling centre.
Sourcing timber
I dismantled an 8 ft wooden venetian blind and kept the slats as I thought they were too good to throw away or burn.
The only problem that restrict their use is the slots that are cut at regular intervals for the various supporting chords.
To my shame I have only used a couple for paint mixing (after chopping them down at each slot).
Sourcing timber
Morning flaxbybuck.
Now that’s an interesting thought….No never thought of that one.
Can you post some pictures of your work please.
I am intrigued,as I am sure will be others.
Regards Bill.
Aimé par stevedownunder and flaxbybuck
Sourcing timber
Has anyone used old Venetian blind slats for boat building ? I have found them to be excellent, the timber being light, strong, fine straight grained and free from defects. First remove the lacquer with a sander and square the edges. The slats I am using are about 36mm X 2mm. Two or more can be laminated to create thicker sections.
I have added a few photos of my boat build. The hull is 1m long. The plan is to make two different superstructures for it, one a cabin cruiser (Fairey-Marine style), the other a pilot boat. The motor is a Turnigy 4240 740Kv which will run on 5S. Whilst the Hobbyking ESC is water cooled, I have added a cooling fan to the motor. With plenty of air volume/circulation within the boat I am hoping this will be OK.
Aimé par dave976 and Mike Stoney and
