How do you draw bulkheads etc, from a 2 view plan?
Commencé par Madwelshman
19 répies 23 aimers Dernière activité : il y a 5 ans
That's a very kind offer Ron, thank you very much.
I am more than happy to send you a copy of the plan to look at, but please don't feel that i am asking you to do anymore than just have a look at it Ron
I should add, that this quest has mostly been to increase my knowledge around model boat building and has never been a plea for anyone to do the hard part for me.
Yes, myself and Zooma would like to build a Stiletto each, so the end result is obviously being able to draw up the templates needed to build them, but this thread has been about gaining the understanding of how some of you are able to work this out from just 2 view plans.
I'm so thankful to everyone who has taken the time to reply to my post, no matter how detailed your reply has been, its all knowledge that I'm grateful you're willing to share with me and others on these great forums.
Ron, the plan I have is on my laptop and not my phone, so I will send it to you tomorrow when I get home from work.
I did have another go last night on some 3d software, at drawing templates using my original 45 degree line method and they look like they could well be correct/close, but how accurate, I do not know.
It has still been interesting having a go though and my plan is to do the same for an Aerokits plan that I also have a copy of the templates for and see how similar (or different) mine are in comparison to those that were done by drawing around parts before a build.
Will
Send me a picture of the plan view you have and I will look it over
Aimé par Madwelshman
Thank you very much JB for your detailed reply, that all makes complete sense.
I will give that method a go and see how I get on with it.
Thank you.
Will
Ron, the only measurements that I have are length and beam, which is a good start at least.
The same applies to any of my Aerokits plans, I know each ones LOA and beam.
I will have to find my protractor etc from my school days, I think I still have it somewhere and I'll get a set of dividers too.
Thank you
Will
Well spoken 👍🍻
Plus you will find measuring tools very helpful such as dividers, protractor, set squares, small easy to read ruler. White gum eraser. a sharp pencil, and patience.
There is a way of doing it, but it requires a bit of guesswork here and there.
This is roughly how boat plans were drawn years ago before computers.
Print your drawings full scale (top and side views) line up the 2 drawings exactly at the transom
For the hull,- vertical measurements
Draw a straight line along the keel as far as you can (don't worry if the keel curves up)
Divide the side view into say 200mm intervals (for the bulkheads)
Measure up from your datum line to all points, (chine, deck etc,) (Do this with cabin later)
Transfer the complete keel shape/depth you require (up to the bow) to another piece of paper with the same datum line and measurements (by tracing)
Make the complete keel (I do it with a double ply makeup with a long slot built into the section for the prop shaft tube so it can be adjusted for angle)
Hull beam measurements
Do the same for the hull, taking in all points up to the cabin (plus whatever extra required to mount cabin)
Mark the bulkhead positions and measure across these points,- this will give you the top width of the bulkheads.
Take your side measurements, transfer them (along with the datum line, wider than the deck width) to another piece of paper, (draw a center line 90deg off the datum line and mark your measurements up the center line.
Extend those out both sides to the deck width lines dropped down to the datum line.
Draw lines from the keel out to these points,- ( this should give you a bottom shape)
This is where the guesswork comes in and a bit of experimenting is required. Cut your bulkheads to your drawing (they will be straight sided) then you will have to blend them to the required flare (if any) and hull shape.
I start with a 5x5mm spine screwed to the building board, over the greaseproof paper covered drawing, and notch the tops of the bulkheads to fit tightly in the correct positions. I then work with a length of 3x3mm balsa or spruce, to get the chine looking right, (look down from the top to check the curve ) When you are happy, mark these points on the bulkheads, (measure one side and transfer) You can then develop your required hull shape from the bottom up on one side. Once done, remove the bulkheads and transfer the shape to the other side.
Cabin sides can be copied directly and with the use of a few cardboard templates, can be built over the drawing as well. Quite a satisfactory result can be had. My HSL, Hartley, and a good part of the runabout were done this way. Hard to describe, but you might get the idea. The full scale Hacker plan might help.
Aimé par Mike Stoney and Madwelshman and
You need some measurements and I do not see any. In an earlier reply I mentioned that these kits have a similar hull design and shape.
Isometric 3 view projection
Aimé par Northernflotsam and Madwelshman
Those drawings are in 3rd angle projection. Ist angle used to be used in the UK, and sometimes called English projection.
You need to draw, i.e. copy those views, Front and Plan , on to some drawing paper, then project an end view. Difficult to explain without showing you. Have you a drawing board and instruments ?
Hugh, have a look at the image attached to my 1st post. If that is what that refers to, then yes.
I would like to know how to draw 2d diagrams for bulkheads etc, from a plan that only has two views, a side view and a top view.
An example of such, would be a Lesro or Aerokits plan.
Will
Are you talking about 3rd angle projection?
Hugh😎
I think it is called 3rd projection drawing. I've forgotten it all myself too and I did C&G in tech drawing !
Your gonna need a bigger boat !
Aimé par Griss and Madwelshman and
Hi madwelshman,
I have just seen you post. That is something I remember from school back in 1964. We used to do drawings like that in Technical Drawing Classes. Not that I can remember how to do it these days. I was 14 back then, 71 now. My problem was I couldn't be bothered to learn too much I just wanted to leave school. I was ok at there subjects, or maybe just liked doing them, they were metalwork, woodwork and the above class T.D. Not that great with maths, well just enough to get by with and those three classes were no good for a job without maths. So I left school at 14ys 11months to go to work in a butchers shop. Stayed there for 7 years then went into dry cleaning and the last 17 years of my working life was driving London Transport red busses I retired back in 2015. Oh boy does that picture bring back a memory or two.
BOATSHED
Thank you Ron.
I have seen that method or examples of mentioned before, but not tried it myself.
Also, thank you for the picture, handy for reference.
Will
Like this? All I had were photos andI knew the cockpit was 14’ but nothing more. Sometimes you just guess and use common sense.
Hi Ron, none in particular really. The Aerokits thing was more of an example if I'm honest.
The one myself and a few others are working on, is a Lesro Stiletto.
But this quest is more for the knowledge of learning how its done and trying for myself to see if I can actually create the drawings needed to build a boat just from a two view plan.
Will
Interesting method, looks simple enough to try this out.
Thanks
Which aero boats are you wanting to draw? Aren’t the hulls pretty much the same? If you know the beam, loa, you can draw up the rest pretty easily by studying these photos. These boats do not use very many frames 5 or 6 max.
Don’t know would like an answer to this also.Thanks in advance.👍
Hi folks, I have a few boat plans, such as Aerokits ones which as many will know are only 2 view and have no bulkheads etc shown on the plan.
Is there a relatively easy way of drawing these templates from a 2 view plan or can anyone point me towards an example/description of how to do this?
I have seen one where you draw a line at what appears to be 45 degrees from above one end of the upper view and extend the line down below the lower view.
You then draw lines out from reference points on the top view, also from reference points on the lower view.
The lines drawn on the upper view, when they meet the 45 degree line, you continue them at 90 degrees down past the relevant reference point on the lower view (if that makes sense).
I have no idea if that is a good way or if there is a better/more accurate way to achieve this.
I am also aware that there are templates floating around for quite a few of the Aerokits range, but I would still like to have a go at drawing some myself, so that I know how to do it for future reference.
How do you guys draw templates?
Thanks in advance
Will
Aimé par Mike Stoney and RedCatcher and
