LiPo Batteries
Abonnés (4)
- mturpin013Bronze
- DuncanPBronze
LiPo Batteries
https://www.robotbirds.co.uk/g-t-power-100a-multifunction-watt-meter-lipo-capacity-and-cell-checker.html
GT power still list them on their home site, but for some reason they are hard to find. They will do everything you need for battery checking. Some shops in UK still seem to advertise them.
A good charger is latest Sky RC IMax B6 Evo,
https://www.aliexpress.com/item/1005003731167659.html?spm=a2g0o.order_list.0.0.21ef1802MLo3Lu
I've just bought one and they seem very good. Sky RC have been making chargers for years, - first charger I bought was a Sky RC ICharger and it's still working perfectly after 13yrs. The new one can have all your batteries and settings programmed in, (up to 10 batteries) so you don't have to re-set every time. Once you have them set, you just pick the battery and press start. Little bit tricky to get the hang of setting, but once you get the idea it's easy. Has alarms if you do something wrong, and stops itself (forget to put balance lead in, wrong cell count input etc) Quite idiot proof.
As Dave said, check you are not charging on the HV setting, - might be why you are getting a strange voltage. GT Power stuff is usually pretty good.
If you have a multi meter, you can test individual cell voltages by checking on the balance plug ie neg lead on meter to neg on plug, then test along the pos contacts (should give you voltages increasing by same amount) eg 3s charged would be - 4.2-8.4-12.6
http://www.gt-rc.com/en/pd.jsp?id=393#_pp=126_765
Your charger should be ok, but it's good to be able to see the individual cells as it helps spot possible problems.
LiPo Batteries
LiPo Batteries
LiPo Batteries
Dave976
LiPo Batteries
dave 976
LiPo Batteries
LiPo Batteries
Great information👍👍👍
I also bought a LiPo bag to charge them in🔥🔥
Trev
LiPo Batteries
Make sure you set the charger to balance charge, Connect the balance lead correctly, make sure the cell numbers and capacity settings are correct, and set a time limit (about 60 mins at 1.5A charge rate for a start from storage voltage, and watch the individual cell voltages carefully while it's charging (if your charger has that capability.) If it looks to be going over 4.2v, STOP THE CHARGER, and if you have set everything correctly, and the charger is not doing what it should, buy a better charger and bin the old one, or try a different brand of battery and see if the same thing happens (for your own and others safety) . What charger are you using ?
You can use a tail light bulb - tail or stop filament,- halogen headlight is a bit fierce (about 4.6A) with a voltage monitor set to 3.8v (alarm setting) on the balance lead, but stay nearby so you can monitor it as well. Once it's down to that voltage put it on the charger set to the storage setting as Mike said. (all the correct settings apply here as well.) Doing it with the charger is a better option until you are fully conversant with LiPos.
LiPo Batteries
LiPo Batteries
LiPo Batteries
You can get a battery alarm which plugs into the balance charge lead and also the better ones read your total voltage and each cell voltage.
Banggood and Hobbyking have them.
Canabus
LiPo Batteries
LiPo Batteries
Any old or dud cell batteries can be safely discharged in a bucket of salt water for a few days (or till the bubbles stop) for safe disposal (I bang a 6"nail through them after that to make sure they are dead) - a good number of rubbish trucks have burnt out from live LiPos being crushed in the compaction cycle.
All batteries with high amp outputs are dangerous (try shorting a fully charged 12v NiCad and see what happens)😮 they can burn your house down too, (I'd guess more cars have caught fire in garages round the world, or heaters, or cigarettes burning houses then LiPos) A lot of uninformed scaremongering about LiPos has put people off them, but as long as they are available, I'll use them every time, especially in planes, (try getting a plane with 2kgs of NmH batteries off the ground as opposed to a 400g LiPo for the same power😁)
Hope this helps PS- if they get wet, just let them dry, (just not in the sun)- probably means if they start leaking,- but you'd soon know if that happened😁 If they fell into salt water, it would just start discharging them.
LiPo Batteries
Recommend follow the guidance and should be fine.
I use a 3s in my RTTL and it works fine - there is a blog on the site.
The cells are sealed so cannot think how a relatively short submersion will damage them. However, they do contain an incredible amount of energy that could short out and do damage.
I always remove both before and after use and wipe down if damp.
LiPo Batteries
Sound like you are doing it right.
When storing them you are supposed to store at half charge, according to the directions.
Trev
LiPo Batteries
LiPo Batteries
I have only used Nimh Batts in the past.
In error I ordered 2- 7.4 volt 2S LiPos.
In the directions it states if they get wet do not use.
Should I even use them in a boat?
Any thoughts?
Trev
Aimé par
Chargement…
