FIRE TENDER POWER
Sorry for delayed reply.
It's not a kit, I built it from a set of plans I bought off EBay about five years ago.
Sadly that vendor no longer seems to be there.
Sorry cant be more help.
J
FIRE TENDER POWER
FIRE TENDER POWER
FIRE TENDER POWER
I have had loads and have lots of food for thought.
J.J
FIRE TENDER POWER
I see you are not far from me at S.O.T., I'm in Sandbach and sail with CreweMBC, are you with the Potteries Club at Westport Park? You are welcome to come and visit any Monday or Wednesday afternoon, details are in the Boat Clubs and Lakes section on this site.
There have been several replies so far and I prefer the last para of CB90's post:
"My own fast patrol boat is 52in long and 12 in wide currently uses 2x 2826 brushless outrunners (fan cooled) 900kv 60A max at 3S (11.1v) with 2xwater cooled 90A Flycolor ESCs.
The motor run a little hot so need to reduce the size of the propellers from 45mm." with 35/40mm props your model will fly and expect 40min plus per run.
LiPo's do need to be handled correctly and you need a LiPo charger using a balanced connector to avoid overcharging and an ESC that will cut the power when the voltage drops below 3.5v. If you are not using the battery for some time then you need to store it at 3.7v per cell and a good charger will have a setting to enable this. I use the Giant Power Intelligent Balance Charger G6AC 50W 6A 12/220V.
Keep your build light and be prepared to add some ballast when testing.
Good building and please post details when more advanced
FIRE TENDER POWER
ESC - Hobbywing Seaking 120A-V3 Speed Controller
It planes easily and last for 20 -30 minutes dependant on how you sail it
check out my build blog
https://model-boats.com/blogs/37275
FIRE TENDER POWER
As for motor the majority of modellers use brushless and lipos these days.
But I'm still old school, brushed motors and lifepo batteries.
My choice would be a pair of 600 motors and a 12v 7ah battery.
But as I said, that's just my opinion.
FIRE TENDER POWER
FIRE TENDER POWER
Well motors batteries and propellers are all a bit of a mine field, you will get a load of different opinions and ideas.
I give you my opinion!
I think you need two large brushless motors something like 2x 3670 with a low kv and water cooling. see
2x Electronic Speed controllers with reverse rated 150 A or more. I like the Flycolor 150A up to 6S.
Lithium batteries (Lipo) and charger.
You will need contra rotating propellers left-hand and right-hand.
I feel that 60mm propellers maybe a bit too big for starters as brushless motors tend to rev higher than DC motors.
I would start with a pair of 40mm.
Read up and save up before buying as this is an expensive hobby, the boat is normally the cheapest part.
RC gear
Motor couplings
Rudders
Water coolings jackets
water pickups and outlets
Be prepared to get bombarded with information and opinions.
Your find help on this site!
Regards Roy
FIRE TENDER POWER
Totally new to this.
I have some woodworking skill though (just scratch built a 48" RAF Vosper Fire Tender from plans) currently in primer, no finishing/fittings done yet but ready to test float.
My question is about motors/batteries. What motors ? What batteries ?
It weighs just over 4kilos unballasted, I've fitted twin 60mm screws and I want it to plane and not need a new battery every two minutes.
Any suggestions would be most gratefully received.
Thanks for taking the time to read this.
J.J
Aimé par
Chargement…
