Swampscott Dory
Abonnés (4)
- Newby7Bronze
- roycvBronze
- Black ShoeBronze
Swampscott Dory
Swampscott Dory
Swampscott Dory
Swampscott Dory
The frames are between 3 & 5 mm wide, delicate!
Swampscott Dory
Swampscott Dory
It might be worth saving the pieces that your "good parts" came from and use them as templates to trace out for another dory.
Swampscott Dory
The kit has small laser cut parts which if you are careful removing them, the parts do not break, but it does if pressure is applied. This small kit’s wood is delicate and light weight so go slowly.
The instructions were very clear, it said to use CA but I used a good quality carpentry glue and small clamps. Some parts of the instructions asked for beveled edges, but frankly the material is so small and delicate that I ignored it. On a larger model sure, but not on this one.
The dory will be painted in the Spring when it is warmer weather, it’s winter in Canada.
I referred to John Gardener’s The Dory Book as a reference for the rudder and sailing rig.
Aimé par
Chargement…
