Holding Jig's
Commencé par Martin555
5 répies 22 aimers Dernière activité : il y a 4 ans
Holding Jig's
Great idea Martin. Just a thought on my part but if you were to use 3 holding screws instead of 4 you can also easily hold hex shapes and still have the ability to center other shapes.
LEN1
Aimé par Colin H and Martin555 and
Holding Jig's
Hi Peter,
I did give that some thought, Maybe a future project.
Martin.
Aimé par Colin H and MouldBuilder and
Holding Jig's
Superb idea Martin. If you bolt them to a plate, add a small electric motor to one end and a couple of bearings to the cap you have a small lathe.
Peter.👍😊
Aimé par johnf and pressonreguardless and
Holding Jig's
Hi Guys,
When I was working on mast's, yard's, or anything that required painting I found It a little difficult as things keep slipping of of blocks when working or painting.
So I knocked up a couple of holders.
These can be used horizontally or vertically and rotated as and when required.
Due to the 4 Allen bolts you can grip round or square in fact most shapes, you are only limited to the diameter of the Bottle tops.
Made from scrap blocks of wood.
8 x 5mm Allen bolts.
2 x large Bottle tops.
And 2 x long bolts for the main shafts.
Aimé par Rookysailor and brokey2 and
