Speed controller or RC failed?
Abonnés (3)
- stotty1111Gold
- luckyduckBronze
Glad to hear Colin's suggestion cleared your issue. Any RC gear that has not been used for sometime can suffer from bad connections. I suggest you carefully inspect all your Rx, ESC and servo connectors for any sign of corrosion or damage. Black wire syndrome used to be a problem and may still be, especially after a winter laid up in a damp storage area. If you do find any damage I suggest you replace the whole wire and connector as the problem not fixable and is likely to reappear and your model may be in the water next time.
OOps didn't find the replies, sorry!!
Aimé par
Chargement…
