Rustoleum Pain Can Nozzle Restoration
I sometimes drop the dirty rattle can nozzle into a small screw top jar (like an airbrush storage paint jar) part filled with thinners - and give it a good shake .
This agitates the clogged paint (after it has had time to soak) and can save risking any damage to the nozzle if you don't have the correct size drill bits to open them out accurately.
Soak - Shake - Repeat. This process can be repeated several times until the nozzle is clear and doing more than one nozzle at a time (if your jar is big enough) helps the agitation and can save time if you have more than one blocked nozzle.
You probably do this anyway.
Whenever I use rattle cans I re.ove the Nozzle after each use a put in a jar of cellulose thinners till next needed, then blow through with airline before use. I even keep nozzles from empty cans the same way so always have a few spares.
Lazy, forgetful, or it just happens, I get some of my "rattle cans", in particular here Rustoleum brands where the little plastic nozzle gets clogged. So, here is what I do to clear the clog:
☹️Pull the nozzle up off the can.
🤣Soak overnight in paint thinner.
🤓Use a .125 inch diameter drill bit to clean out the paint on the inside (do not drill through).
🤓Use a .030 inch diameter drill to clean out the nozzle hole to center hole. (do not drill through).
🤓You might need to repeat drilling steps several times.
😮Blow out any particles.
😉Replace nozzle (not to hard to avoid accidental spray).
😊After this I have not noticed any difference in the spray pattern - works great.
Florida 🌩️☹️ today, USA
Aimé par
Chargement…
