Glue for wood to Plastruct?
Florida 🚤, USA
○ If you can make sure the joint is wide enough (more contact surface area) need to increase?
○ Make the plastic surface a little rougher (not fine), and make sure any particle are cleared (clean with alcohol).
The HV version sits on the surface rather thank wicking away so remains in place while putting on some light pressure for 30 seconds until cured.
https://www.toolstation.com/hv-super-glue/p78871
Styrene and wood joins with CA usually work. Is the plasti-card a vinyl? Vinyl can be resistant to many of the glues that we are used to. JB Weld or Devcon 2 part epoxy...the clear smelly versions (not JB's black "metal" super slow 2-part epoxy) should work re: Fred's suggestion. BTW: I'm with Barry on the alcohol cleaning!
You might try cleaning the plastic with alcohol before using epoxy. Slightly roughen the areas you will glue with fine sandpaper.
Try it on a piece of scrap. Some plastics seem to have a coating on them from the manufacturing process.
I hope this helps, good luck and you are doing a nice job on the boat!
Barry
I have been using Devcon 2 ton Epoxy, I got mine from my local model shop
You have a 30 minuets holding time and a full set in 8-12 hours
Fred
Tried the liquid plastic glue and the gel type used in plumbing both don't hold on the wood. Tried wood glue, CA & epoxy and even tried sanding sealer on the wood first.
Picture is the structure of cabin and upper deckhead which I plan to skin with plasticard.
Job stopped until I find a solution.
Aimé par
Chargement…
