Forward and Reverse control for TVR 1A Engine, and coupling solution.
Abonnés (4)
- NickthesteamSilver
- Newby7Bronze
Good to know 😊
The solution to the coupling problem is don't use one, fit a fly-wheel to the engine with two contact pins, and a tee bar onto the end of the prop-shaft. After all, you can't have a coupling problem if you don't have a coupling. Regards, Gary.
Aimé par
Chargement…
