Boat colors
Commencé par Isaac
10 répies 54 aimers Dernière activité : il y a 3 ans
Boat colors
Red lead oxide spray cans are available from most good auto parts retailers and seem to be the same colour regardless of make look round for best price Halford can be on the expensive side for paints peter l👍👍
Aimé par Len1 and Isaac and
Boat colors
Isac IMHO it is probably better to just repaint the entire bottom because you may not know how well the locally repainted areas will hold up over time. Len
LEN1
Aimé par RNinMunich and RossM and
Boat colors
Thanks mates
I just epoxy repaired the hull and will float test it first. 🤞
I have the spray paint the affected area and see if it is close. If not, I’ll repaint the entire bottom
Isaac
Aimé par Len1
Boat colors
If you're going to paint the entire bottom, matching a particular color isn't real critical. I've found any reddish-brown ("hot rod") primer to work in the majority of cases. I would agree with Jumpugly that test patches off the boat should be done in any case.
I also understand that enamel will work over lacquer, but lacquer won't do as well over enamel because of the different rates of expansion/contraction enamel being more forgiving.
Aimé par Len1 and stevedownunder and
Boat colors
Hi Isaac,
Argueably the best you can get is the Tamiya spray paint Hull Red (or Dull Red) TS-33. Its very expensive but unbeatable.
If you look at the pics of my Puffer, you'll see what it looks like in action.
Good luck,
Bryan
Aimé par Isaac and Len1 and
Boat colors
Grab the Rustoleum primers too for tests. Also check out their Satin Claret Wine. It's almost spot on Colin's red lead oxide. Their main upside is they gas out faster than the Krylon paints. They also spray very well for a rattle can over a large surface area with a more robust nozzle, not to mention that they are cheaper than Krylon. A few test sprays on primed scrap is ALWAYS advised. On a personal note: The Krylon Fusion paints stink to High-Heaven and can lead to a one way ticket to divorce court, but their gloss quality is great. 😉
Also, my son has been steering me towards GamesWorkshop/Citadel Paints. But, the top of the line rattle cans by "The Army Painter," and are all the rage with the "games figures" crowd, although at $20 a can they are pricey! But they set fast, gas out well, and dry super flat. Truth be told, I have to do more experimenting with these Warhammer paints...I'm not sold on them yet despite their color variety.
Aimé par stevedownunder and AlessandroSPQR and
Boat colors
That looks to be right you could put a matt or semi matt lacquer over it to give a tough surface.
Aimé par Len1 and jumpugly and
Boat colors
Thanks Colin
I was thinking of these two paints
The lower is Ruby Brown primer.
Isaac
Aimé par Len1 and Mike Stoney and
Boat colors
Original colour red lead oxide.
Look for auto/car rattle can primer I believe Halfords has a can to suit.
Aimé par PeterL3 and Len1 and
Boat colors
I am in the process of restoring this large ( 6 ft long ) model of the USS Porter torpedo boat from the era of 1896.
There is damage to the hull, and after repairing it, I wonder about the hull lower color which appears reddish / brown.
Anyone know what it is and what is the closest commercially available paint to get ( spray can is OK ). not looking for exact match.
The upper hull appears to be battleship grey and I found a Rustoleum spray can for it.
Thanks
Isaac
