Newbie advice
Newbie advice
As suggested small is the order of the day.
For power use two minI servos stripped to their bare components. Use the pots to set the central off position then use a Y lead to connect both servos to your radio. Use another minI servo to control the rudder. As suggested mount this sideways to clear the deck. Power can be a receiver battery 4.8v. Props will be small and as also suggested should be light. Use silicon tubing to couple the props to the motors.
I suggest you make the top removable and join to the hull with some plastic channel all the way round. SHG do mail order and may have all the bits you require.
This makes into an attractive model, and for very small garden pools etc will sail fine.
Good luck and please post some pics to show how you are progressing. 😀
Newbie advice
goin to post as many pics of the build .
Newbie advice
Think small and light, anything can be controlled, its just how!!!!!!!!
Constructive thinking, move the servo to an area which is fairly high or lay it on its side, there is a way, we just have to find it
Newbie advice
Many thanks for your thoughts and tips.
I will post pics, true small hull. Major problem is the lower deck 30/40mm height .
I'm over in west of Ireland.
Many thanks again keep ye posted
Joe
Newbie advice
The problem you have is capacity, at 13 inches the hull is small, so minI motors possibly 280,s and a 9gram servo, small ESC are easy to find on ebay batteries, use AA 6volt pack or 7.2 volt, these will be light or LiPo cells are even lighter,
Don't go for heavy prop shafts in brass, Hobby King have alloy prop shafts, keep thinking light weight through out your build, you can add ballast but an overweight boat could very easily sink!!!!
Take time to think your next move, take photos, post them let us see where you are and literally dozens of people will help.
We made our mistakes, we can help stop you making them again.
Im in Greater Manchester, if your local I could help
Newbie advice
Newbie advice
Thanks James
Aimé par
Chargement…
