Aerokits Sea Rover
Aerokits Sea Rover
I have also found motors to be noisy on the bench, but when you put the boat in the water it doesn't sound so loud and sometimes even like a real engine. So I don't fuss about it too much, but I have picked up that the propeller shaft is the actual source of the noise and not the motor. Disconnect the coupling and rev it up again. See if the noise is less. A slight imbalance on the shaft, amplified by the wooden hull like a guitar, make it sound a lot worse than it is.
You can also try a softer rubber for the mounting. I don't use a metal mounting. I make my own wooden ones out of super-wood. So I cannot comment on the role of the mounting in the reverberation of the noise. And as a last resort, line the hull with "mouse pad" foam. Not sure what it's called but here locally we buy it in A2 size sheets. It has some sound damping properties.
Aerokits Sea Rover
Aerokits Sea Rover
I respect the kit manufacturers that have revived some of these designs but the construction has been changed to suit modern production methods and materials and to me they are just not the same.
Aerokits Sea Rover
Sea Rover is about 29" length I think? Will go well with modern electrics. Good luck.
Aerokits Sea Rover
I just picked up a donation to the club.
It's a partly built Aerokits Sea Rover.
The kit still has the original nitro engine in perfect nick.
Unfortunately, I cannot restore it to the original form, and will have to convert it to electric.
When I do get started with it in about 3 week's time, I will share the build on a new blog.
Attached however is a photo of a Sea Rover.
Aimé par
Chargement…
