Sail servos
Sail servos
Would moving the mainsheet attachment point on the boom closer to the mast give you more range of movement of the boom to full out?
I do this alot with the DF65 to adjust the boom because it is so simple to adjust the attachment on a DF65
Sail servos
Sail servos
Sail servos
This is going to be a BUSY pulley. can you put the tensioner on the back side of the loop? 2 idler pulleys side-by-side with the tensioner pulley between them, pulling away. the usual method. see also my KUBOTA picture. I think some elastic line might suit you for the tensioner spring
Sail servos
expanded size for display. Tightened and half tightened
Then tie the mainsheet to that loop
repeat to tie the elastic to the mainsheet 4 inches or so down the line
anchor elastic other end to the SHEET SIDE of the loop
Sail servos
Elastic is tied to the mainsheet, about 4 inches down
Elastic begins to stretch as the mainsheet rounds the pulley
This keeps the tension on the mainsheet as it rounds the pulley
Travel is about 4 inches more as the mainsheet rounds the pulley
I think all you need is an 8 inch elastic in the right place
Sail servos
Sail servos
Sail servos
I am thinking that the elastic will be too tight at full extension and too slack at retraction. SET THE ELASTIC ON THE OTHER SIDE OF THE LOOP
Can you bring the mainsheet AROUND the upper PULLEY to gain the extra length? That would mean that you would have to rout the MAINSHEET right along side the PULLEY LOOP line and attached to the elastic that tensions as it rounds the pulley.
Have the ELASTIC line tug on the MAINSHEET, JUST AS IT STARTS AROUND THE PULLEY, to keep it seated in the pulley. Is that what you were thinking in your diagram? So the elastic would only have to stretch the distance between LENGTH BETWEEN THE PULLEYS and LENGTH OF MAINSHEET. Approximately 5 inches. Shows ELASTIC at FINISH POINT
Sail servos
Sail servos
Sail servos
Instead of running the sheet from the 'too short' MAIN SHEET LOOP, (because the loop is too short), run the required LEVER from the MAIN SHEET LOOP.
How much lever length-arc do you need to run the MAIN SHEET?
How much run do you have on the MAIN SHEET LOOP?
Sail servos
Sail servos
Is there a tensioner pulley? I have spent many years with continuous loops and tensioner pulleys. The tensioner pulley is in the centre, the spring is along side it (a Kubota). It doesn't slack or tangle
BillH2 is correct
Sail servos
In addition to the images, I would like to know if possible: how much is the surface of the mainsail, how much does your boat weigh, do you have space for the lever bar in your hold, how many turns does the winch make, does the sheet wrap directly around the drum or have you created the system closed loop?
Sail servos
Aimé par
Chargement…
