Mini steel drive chain and sprockets required.
Commencé par GaryLC
6 répies 34 aimers Dernière activité : il y a 2 ans
Thank you for this link. What a great resource to have available. Prices are very reasonable
Everyone should check this out they have lots of great stuff including pulleys and universal joints
Aimé par SimpleSailor and Peejay and
No rocket science involved Len😉 Took about 2 mins.
Mr Google told me where to look. Mostly German firms. I just posted the first UK firm I found.
But I had a shrewd idea because I have the same low propshaft problem with my cutter Gina 2. A few years ago I bought some toothed belts and wheels from a German company, Krick or Conrad?, to solve the same problem as Gary has.
Doug, thanks for the linc for sprockets and belts. So hard to fine. Len
LEN1
Aimé par GaryLC and RNinMunich and
Hi Gary, I'm glad you found a solution already, thanks to Doug.
For me, however, the great and good news is that you are building a new steam model.
For me it's a model just to be admired, I can't wait to see some images of the developments.
Aimé par Peejay and Len1 and
Thanks Doug, much appreciated and just what I was looking for and couldn't find. I am pretty sure that I can make that work for me.
Regards, Gary.
Hi Gary,
Maybe 'Old Blighty' can help😉
They do both plastic (with brass hubs) and steel sprockets and chains.
https://www.gearsandsprockets.co.uk/sprockets/
https://www.gearsandsprockets.co.uk/model-making-chain-and-sprockets/
Aimé par SimpleSailor and Rookysailor and
Could anyone out there in the ether possibly steer me in the right direction to find some mini steel chain and sprockets, as used for the drive chain in I/C nitro model cars, the sprockets to have a hub centre of 3 - 4mm for drive shafts of the same size. Although of course the centres could be drilled out to suit. I am hoping that the good old US of A. can deliver the goods for me, as there seems to be nothing in the U/K. In my searches so far. I am in the process of building a Lady Jane open steam launch by Maxwell Hemmings, and the prop shaft when parallel is, or will be about an inch lower than the steam engine. Hoping you can help me. Regards, Gary.
Aimé par IanL1 and Len1 and
