Help identify a part completed project
Commencé par BillA
13 répies 87 aimers Dernière activité : il y a 2 ans
#14 1
Hi there
Just to give you some idea of what can be achieved with the internals of the boat, without removing the deck - these models require a small amount of power to push them along at quite a speed. So, in this model that I built there was a 385/400 MFA motor driving a 35mm 4 bladed brass prop. I used (I think it was a 7.2 NiCad battery). Bear in mind this model was built in the 90s - the weird looking circuitry either side of the motor on the strip board is an actual home made speed controller. As you can see, there is a standard servo which I fitted and a miniature receiver. There is also room for a power supply of 4.5 volt for the radio gear.
With today's new technology and cheaper speed controllers from China - which we will all have to buy awfully quickly - so we have plenty in stock for future projects - I can see no problems with fitting out this little model.
One thing to note with the model I built, it was plank on frame and not balsa wood.
The funnel was made from a 'Haliborange vitamin C tube'.
John
Aimé par Isaac and Len1 and
#12 1
Bill:
You got your hands full on this one.
Is the below deck sealed or you have to redo it?
Aimé par Len1 and hermank
#10 1
John - thank you so much for that information - it certainly looks like the boat. The power of being able to tap into enthusiasts!!
Ronald - The deck is secured, but I've got a shot of the "below deck" by taking the superstructures off. see attached
Aimé par Len1 and hermank and
#9 1
Since I work in a dispaly company and we do lots of boat shows down here in Miami, Ft. Lauderdale and West Palm, we receive lots of damaged company's models .
This is me fixing one of them.
Aimé par AlessandroSPQR and Len1 and
#8 1
Marvellous detailing Chug👍👍👍
#7 1
Thank You John:
The old picture you found shurley helped you a lot.
The same thing happened to me when I was building my Sub Chaser.
I found a bunch of realy good old pictures considering that they where from 1914.
Those pictures helped me create a bunch of extra detailed parts.
Here is a sample.
Hi ya there,
Thank you for your kind comments. The model has been made for a while now - something like 20 0dd years - the figures are 1:35 Tamiya make and I think they are the loading crew off the flack gun (if I remember rightly). I think the figure standing at the side with a blue suit on, came from Deans Marine, because he is made from white metal. I have been on the Deans site - but - I cannot find any at 1:35 scale, only at 1:24 and some smaller - as in 1:96 scale.
I have heard reports that the figures you receive, you may have to do a good bit of work on them to make them look respectable. I Hope this helps.
John
Aimé par Len1 and RodC and
John:
The model it looks like museum piece.
Great work.
What scale is it? I ask because I’m looking for 1/24 seamen figures but what I have found is not that great.
Aimé par AlessandroSPQR and hermank and
Well Done, John! That fella got an answer to his question in 18 hours. Amazing the resources people have here on this website.
Aimé par DWBrinkman and peterd and
hi there
That model looks remarkably like a Vic Smeed design of a Customs Launch - which was a free plan many moons ago in Model Boats Magazine. There is also a very similar design / model which is slightly larger but I believe it is based on a vac formed hull. Similar style customs launch - give me time to wake up 🙄 and I will look for some photographs and plan references.
The plan was first published in the Model boats mag in Jan 1982 👍
https://www.sarikhobbies.com/product/guardsman/
John
Aimé par SimpleSailor and RodC and
Are these deck structures secured? Could you remove them and show us what it looks like below deck?
The X on top of the one roof appears to be where the Stack would be located. The front tall structure would be the Wheelhouse.
Aimé par RodC and Len1 and
Hi - I took possession of this part completed build some years ago when my father passed away. Unfortunately I didnt find any plans or references to what the finished boat should be. Many years later, I'd like to see if I can finish it!! Its all balsa construction, and the overall length is approx 25".
Can anyone help??
Thanks in advance. Bill
Aimé par Mike Stoney and SimpleSailor and
