Fairey huntsman ladder
Commencé par Wez
8 répies 50 aimers Dernière activité : il y a 2 ans
I agree with you John👍
The two joints we can see are a bit lumpy, indicating that the solder did not flow and attach to both parts properly. Typical sign of not enough heat, or possibly the parts and/or iron tip are not clean.
If the parts are not clean surface oxidation can prevent proper flow and bonding. I always clean both parts with 600 grit wet and dry paper.
Typical multicore resin solder needs an iron bit temperature of around 250-270°C.
I use 0.5mm diameter solder for electronic work, 1mm for brass/copper work.
25W iron for electronics, 50W or mini gas torch for metalwork.
Wez; A proper joint should show a clean, smooth, shiny curve between both parts.
Any 'joint' that looks dull grey or silver is a bad/cold one.
A clean iron tip is also paramount! When it's hot, and any residual solder has melted, clean the tip on a damp sponge. Then 'tin' the tip with a little fresh solder which should flow around the tip IF it is hot enough. If not the solder collects in a ball on the tip indicating that the tip needs cleaning and/or more heat.
This thin film of fresh solder is necessary to ensure proper heat flow to the two parts to be joined.
Your first attempt is quite creditable Wez. 👍
Hope this info helps with your next creations Wez.
@Barry: Like you I spent many years working in electronics, 47 to be precise. Tempus fugit🙄
And just as many years as a hobby, home made ESCs, special function switch controllers etc. etc.😉Nowadays with inexpensive 'thumbnail' size modules it's hardly worth the effort, BUT I still like the challenge😁
Aimé par Peejay and Len1 and
Making jigs for this sort of work pays off. well done Cheers Ian
Ian Langley
Aimé par Len1 and hermank and
You've done well, I struggle on straight forward electrical soldering. Neil
I'm pretty sure it's a lot better than I could do and I was in electronics for over 20 years, both as a hobby and as my career.
Nicely done.
Wez, the ladder looks really good.
If I might offer a suggestion, I looked at the solder joints
and it appears that the joints need to be a bit hotter than
you are getting them.
The solder should be very smooth connecting to each brass
part.
Try some scrap brass pieces and see the difference in a
"cold joint" and one that is hot enough.
Congratulations on taking on a new challenge and enjoy the experience!
Barry
You've made an excellent job of the ladder. A very good finishing touch to the boat.
Aimé par jumpugly and Len1 and
Nice one 'Cyril'👍
Inspires me to fit one to my Sea Scout😉
Doug😎
Aimé par Peejay and JohnJ1 and
So last couple of days has ended in this finish ,I hope it’s up to scratch as it’s my very first time soldering ,after making a jig well an old sale board with a couple of holes in to keep the frame straight and a few washers and bits of wood finally think I’m getting the hang of soldering ,bit of clean up to do but I’m pleased
Aimé par Rookysailor and IanL1 and
