Has anyone built the HA-Kits Flying Christine II Ambulance? boat
Abonnés (8)
- FredBronze
- RookysailorSilver
- jumpuglyGold
- roycvBronze
- DuncanPBronze
You mention the bending of the skins, the bottom skins go on ok, but putting on the side skins, there is a hell of a twist to get them on the prow, I resorted to screws, after pins would not hold it.
Cheers, Pete😊
hope you have much enjoyment building her.
Cheers, Pete😊
Was it the bending of the skins which was a problem when fitting?
Thanks guys D
My son and I built our version of Flying Christine 2 a while back. It wasn’t that easy! The rudder operation has always been suspect . I cut a hatch in the aft deck to allow easier access.the servo is mounted in the cockpit. Careful
Ballasting is necessary too
Good luck!
I have built the Flying Christine II, she is a lovely boat to build, putting the skins on was the hardest bit, regarding the rudder, I used a standard size servo, but make sure you connect everything regarding the steering, before you glue on the transom, and best of luck with everything.
Cheers, Pete😊
You get 0.5 kilograms at about 1 cm so enough power for a rudder with a 9 gram servo and they are cheap as well.
I prefer to put the engine as far aft as possible because in this way the propeller shaft is shorter (and this has many advantages). However, I realize that, if it is not possible to position the engine low, then it is better to lengthen the propeller shaft in order to reduce the inclination. Very good.
Also 122 grams is around the weight of the receiver plus a rudder servo and maybe a very small esc.
So this weight saving is worth doing, I am not saying a 600 would not work but the battery will have to supply that much more power so the lighter you make the model the longer it will run.
I have run 3 fast boats with both above options. All 3 planed nicely the one with the 380 had a 1 : 2 reduction gearbox and on 6 cells was almost uncontrollable. It is 16 inches long (Huntress) and in my harbour for reference and before battery settles down there is just 2 - 3 inches of boat in the water, she is very light in weight.
I had 2 Bobby launches with 540s in and 6 cells they were fast and we used to sail on a shallow stream, not quite a river. On one occasion one of them was seen to put a spurt on although already at full speed.
It turned out it had shed a blade of the 2 bladed prop and actually went faster!
Now I sail displacement boats and yachts, however I shall be out sailing with friends on Wednesday and have just re worked an Airboat. Now that goes fast and has a mind of its own!
I love displacement boats.
So I'm asking you this question just out of curiosity, to learn from you.
I looked at the Graupner brand (to have an example reference) and I found that the difference between a Speed 600 [195 grams] and a Speed 400 [73 grams] is 122 grams.
Do you think that 122 grams on a weight of 1.63 kg can negatively affect planing?
This is very interesting to me
That model needs to be no more than 1.5 Kgrms to plane easily.
I would opt for an equivalent of the Speed 600 but I know I will attract a lot of criticism (moreover justified).
However, this could be useful for your choice:
https://model-boats.com/forum/147506
https://model-boats.com/wiki/147457
I use 3 off 0.1 microfarad capacitors. One between the brushes and the other two from each brush to the body. That gets rid of most of the RF interference.
If you are using 2.4Ghtz RC then you do not need suppression but you will affect any other users on the other frequencies.
The capacitors cost pennies but check electronics suppliers you need a working voltage of 50 volts for the capacitors.
regards
Your idea sounds sensible a small bow wave will look scale as well. The small motors intended for Bruma will not be powerful enough for Flying Christina.
Main thing is to keep the weight down. As a collector of motors I have a lot but the 380 is very cheap. Or perhaps the Speed 400 would suit but do not pay more than £8.50.
Hope this helps.
P.S. Hopefully I'll get Bruma finished before starting this one!!
A 380 motor (40 watts) not a 5 pole low power one would work but with an even smaller prop 30mm, would work as well. This is due to the high speed of the motor.
Generally 20 watts maximum would drive her very nicely 7.2 volts at 3 amps load.
I do not know much about brushless but I expect others on the forum can advise.
Nice choice, will be pleased to see photos of your build.
I've just bought the above kit to build with my grandson during the summer holidays. He is 11 years old and has enjoyed sailing my boats. I want him to get interested in building boats - rather than just playing and watching football!!
Because of the inherent dangers with LIPO batteries, if not cared for and handled properly, I want to use NICAM batteries with a brushed motor. Has anyone any suggestions of batteries and suitable motor for this 32 inch model?
Also because of the low drop down cockpit at the rear of the boat does anyone have suggestions on the type of rudder servo and the mounting of it in this limited space please?
Any photos and videos will be much appreciated. I want the build and performance of the boat to be good so as not to 'put him off'! We need to get youngster's interested otherwise our wonderful hobby will die a death!
When we start in the summer holidays, I will start a build blog of this boat for future builders.
Cheers everyone,
Duncan
Aimé par
Chargement…
