HiTech Winch Drum
HiTech Winch Drum
Found this photo from someones' build and you can see that the central ridge is in place. He mentions that it uses a loop system for operating the sails, is this what your instructions call for?
It's a big model and the force from the sails will be large, which Hitec servo do you have as they do a bigger, more powerful one?
HiTech Winch Drum
You could also put the drum onto a suitable bolt to use as a mandrel so it can be held in an electric drill and spun. This would allow you to "machine-off" the ridge with whatever tool you feel happy to use.
The drill will need to be held firmly to do this safely.
If you have access to a lathe, you will still need a mandrel to hold the plastic drum whilst it is being turned.
If you don't fancy machine "turning" the spool in any way, it can be filed and sanded back by hand and with care can produce a very acceptable finish.
HiTech Winch Drum
Or if you know someone with a small lathe and can mount the drum then that would be a better solution.
HiTech Winch Drum
Aimé par
Chargement…
