Dumas Brooklyn Tug
Commencé par puttn
24 répies 83 aimers 0 abonnés Dernière activité : il y a 1 mois
#24 18
Did I post this early?
It was sailing this past Sunday at our meet. A RTR heavy plastic Brooklyn Tug. Not much for ballast and certainly not scale running as can be seen in this video.
It also spayed water at the kids.
Aimé par USA Corsair and EdW and
#23 19
@Ronald couldn’t find the 2 pieces for the rudder assembly for the fiberglass hull. So I just used the pieces for the plastic hull and incorporated them to the fiberglass hull. The deck is built next step is planking. Stuffing box is installed. At the present moment I’m working on 2 boats. The other is Dumas Donzi sport fish. Time is definitely not on my side trying to find it to work on either one.
Aimé par hermank
#21 24
Hi Ron! Due to a series of unrelated work and home repair issues I've not been on the tug boat for a bit. Now that I am away on vacation i've delayed it even further. However, just before leaving on vacay; I started weathering the superstructure and wheel house and am retrofitting (trimming down) the original drive system to fit into the newer Dumas 2-piece model hull. I am also trying to figure out the best electronics combo to marry to the original Dumas 12V motor with speed control etc. So, when I get back I'll jump back in with both feet.
Aimé par hermank and Ronald and
#19 34
Many thanks Dave!
It always helps me to be curious with things like this in order to stay on a budget. Especially these days! Everything posted on these pages has and will always be a help to me. And in this case I too am wondering about going with the original Dumas offset geared set up. I have built the drive system, but not fully committed to it yet.
Aimé par hermank and AlessandroSPQR
#18 36
Guy,
It is an older build. I didn't build it; I acquired it from a club member who needed to downsize.
I'll attach some pics from the inside of the boat for your reference.
Aimé par USA Corsair and AlessandroSPQR and
#16 46
I don't know if this is any help or not.
I took a couple pics of mine.
If I can do anything else, let me know.
PS I don't have the plans for the boat.
Aimé par AlessandroSPQR and EdW and
#15 46
I just got a reply from Ed on my email requesting that he reach out and help.
I send him your contact information on the website so hopefully he will reach you.
Ronald
Aimé par hermank and jumpugly
#14 46
I can only provide half of your request, but you're welcome to it.
Aimé par chugalone100 and hermank and
#12 48
Hi Ronald & puttn,
Ed Figuero's Brooklyn Blog immediately sprang to mind with me as well.
Link to the Blog below.
I don't think he ever launched it😒
All we got was a string of 'reasons' why not, then he had considerable family problems and he kinda disappeared.
https://model-boats.com/blogs/38209
Aimé par jumpugly and Ronald and
#11 48
I recalled that Ed Figueroa ( figtree7nts) did a long series of posts on his building of the Dumas Brooklyn Tug. I have reached out to him since it’s been 7 years now since he began his building blog on this website. We were all waiting for photos of the launch but I am not sure it ever happened. Let’s hope he kept the plan sheet and will be able to assist you with the missing details for your rudder assembly.
Aimé par jumpugly and hermank
#10 55
@Ronald
Sorry I missed you last night Ron! Thanks for the message!
I was driving my daughter back to her apartment in NYC. Dark and wet drives to NYC are
always a serious pain-in-the-ass. By the time I got home I was dog tired.
Aimé par hermank and premecekcz
#9 55
@jumpugly
Agreed, thanks for giving your suggestions.
Regarding putting small screws into the fibreglass hull, if he applied epoxy to the area first and filled it about 1/4” or more, before drilling the pilot holes fore the screws, he should be fine.
Aimé par hermank and premecekcz and
#8 55
Puttn: finding these parts would be almost impossible. Although a decent set of plans from the older versions would be the way to go in order to fabricate a set. In this case I might just go with the modern plan template for the brass keel extension. If you don’t want to drill into the fiberglass hull for the screws, I would then fiberglass the brass keel extension directly to the hull.
Be that as it may and considering the photo you have of the parts I would start hitting the building blogs to see if any of those builders might have some leads towards the actual shape and dimensions.
One thing I would definitely do is post your photo on the Facebook “Radio Controlled Tug Boats Only” page and let that gang know what you are looking for.
Aimé par AlessandroSPQR and RodC and
#7 55
Ronald it looks like a boat that was down at the local boat club.
Now my comment is off topic the bot in question as set alight but before that shameful act I scrounged a few planks and the lane logo the boat was 'The Dolphin' I used the planks for a DIY camera Col
Aimé par hermank
#5 56
@Ronald yes I’m pretty sure they’re metal. I have everything for the rudder assembly for the 2 piece hull. But did not realize the 1 piece fiberglass hull is different for the rudder mounting. I’m thinking I could use the set up for the 2 piece hull. But would rather have those 2 pieces. We shall see. Thanks
#4 57
@puttn
Those are very unique to that particular style of tugboat. Never having built one of these Dumas tugs, would these be White Metal castings?
I could imagine they are white metal casting which with some careful fabricating, you could duplicate them using brass bar, brass rod and brass tubing?
Aimé par RodC and hermank and
#1 72
Dumas Brooklyn Tug
Looking for some help. In search of the 2 piece rudder post for the 1 piece hull. The upper and lower rudder post. Any help would be appreciated. Thanks
Aimé par stevedownunder and chugalone100 and
