Battery
Battery
They're easy enough to fit/remove to see which you prefer.
Battery
To be honest I have little faith in that way of doing things. if you drive both ESCs and your rudder via a single mixer you have a much simpler control setup and will need a smaller brain plus only 2 hands.
http://www.action-electronics.co.uk/pdfs/P40D.pdf
There is an example of the sort of setup I was thinking of.
Battery
Battery
if using BEC from ESC(s) remove the RED lead from 1 ESC. ( if not you may fry your receiver)
you may also consider 1 left hand and 1 right hand prop so you reduce torque effects.
fitting a mixer twixt throttle and rudder will allow you to get differential motor outputs as you steer.
Battery
Battery
So you should be good to go just keep a check on ESC temps with your prop.
I am guessing you know about looking after/charging nicads ( can you still get nicads?)
Battery
Aimé par
Chargement…
