recharging NiMh batteries
Commencé par octman
3 répies 0 aimers 0 abonnés Dernière activité : il y a 10 ans
Thanks, that's what I thought.
No not if the"Y" lead means both packs are in paralegal, ie if the output voltage from the Y lead is the same whether one or 2 packs connected. The charger can't determine which pack is full or not. if in series it's fine, however you'd need a charger capable charging the total Vols across both packs. For example 2x 7.2v packs in series needs a charger capable of 14.4v or as they usually state 12cells. Not sure they would charge any quicker like this. Better having more than 1 charger if lack of time is the issue. I have 2 multi, 1 gell and a dedicated lipo charger.
Simple question- I have two identical battery packs, which get discharged at different rates. Can I recharge them at the same time with the same charger using a Y lead? Will they both be fully charged if they do not have the same charge to start with?
