Proboat Volere
Proboat Volere
if you can get inside the boat consider change of motor and esc. ( and go lipo)
Proboat Volere
It's still too cold where I live, Pennsylvania, USA to run any boats. I do have a new prop on hand so I can try that first when the weather cooperates.
Looking at the Proboat website, I saw two interesting new models. One is a PBR,(was showcased in film Apocalypse Now) that's not released yet. it is powered by twin water-jets. That is one that has been on my build list for a while. So now maybe I will just buy it. The website says it has operating lights and provision to make the forward turret rotate. Sounds good to me.
The second is a race boat also powered by a water-jet. I am primarily a scale boat builder but I always wanted to give water-jet propulsion a try.
Proboat Volere
I suspect the model is on the heavy side. I saw a similar model at the E-Port show and it was heavy without any motors or batteries installed. This will be causing the symptoms you are experiencing. The u-tube post shows the same problem. it really needs to be constructed of very light materials. They do look beautiful but at the cost of weight.
Proboat Volere
if its the same boat then it would seem there may be a problem with your setups
Proboat Volere
I to have the ProBoat Volere, I have left it as is. it does have good performance however it does push water as if it were a tugboat! I believe it's the design of the hull!
Did you see how to get in to the hull? I don't see how to and so I left it alone! all an all it's a good little boat.
Oh, talk about a huge ESC....
Oops, Looks as if I'll have to fix the stand!
73
Proboat Volere
Aimé par
Chargement…
