Aerokits Solent Class Lifeboat
Commencé par olly49
1 répy 2 aimers 0 abonnés Dernière activité : il y a 9 ans
Hi Olly. As you have the 850 motors, what about 2 - 1 belt drive from MFA, there website gives spacing and belt length details. This might give a slight improvement in speed and endurance.
Etherow Model Boat Club
Aimé par Gravedigger47 and suntugs
Built in 1981 and the cabin superstructure refurbished a couple of years ago.
The original motors are 2 decaperms that are getting very hot now.
Brushes changed in one of them which now seems to be lazy.
It is now time to change these for a more modern type of motor.
Because of the distanse from the hull to the middle of the shaft a 850 straight shaft to propeller shaft will not fit.
I've decided to fit 2 bearing blocks to the underside of the mount and fix a pulley gearbox to the prop shaft.
The decaperms where 2.75:1.
What would be the best ratio for my new setup?
olly49
