Brush-Less Motor ESC/Data-logger
Commencé par sunworksco
2 répies 0 aimers 0 abonnés Dernière activité : il y a 16 ans
What are your specifications for the boat, prop,battery capacity, motor KV. I think that those BL motors will be fine on direct drive if the KV is around 200.
I find it laborious to find brush-less motors that have kvm ranges as low as I need in the can sizes I need, so experimenting with programmable ESCs and data-loggers are necessary.
For example, on one ESC, it can have the throttle range be 10% or 20% of true throttle range, so a 2800 kvm motor magically becomes a 560 kvm motor...
another esc ( Castle/Phoenix ICE ) allows the user to program an exponential throttle curve, so at 90% throttle on the radio, the motor is at 30% of maximum throttle. then I set the transmitter so that at 100% of throttle stick, I am only sending 85% of the total value, so I end up with a motor that tops out at 25-28% of its max rpm. This is what is so liberating about programmable ESCs with data-loggers.It is also very reassuring to use the programmable low battery fail-safe for Lipo and LiFe battery packs.It is getting much simpler now that many BL motors are being experimented with.
Regards,
John
Regards,
Giovanni
HI John
Do you have any details to use these motors in a model boat? The data sheet is aimed at model planes. I see that the max efficiency current is variable between 30 - 60 amps and wonder if you have used the amp/wattmeter to take any measurements. is it possible that at lower speeds the wattage may exceed the esc/battery capacity with much wasted energy converted to heat. I have just ordered a wattmeter from GiantCod here in the UK and intend to check my brushless set up following an incident (thankfully not serious) with a LiPo. Hence my interest in any data you may be able to share.
I have been doing research on Brush-Less ESC/data-loggers and found some Interesting products.
One product Is the Robbe Roxxy Marine 940-6 ESC/data-logger.
This model has a very good reputation and Is pc programmable. http://www.rcmarket.org/bl-roxxy-950-6-pr-21008.html
Then there Is the www.raczing.com programmable BL ESC/wire-less Wi-FI data-logger that sends a live view to a Motorola Android or Windows 7 pc.It should work with the new Windows 7 cell phones that were just offered this week.They say that they will be making a marine version
( reverse programming ) soon.
One of the most sophisticated telemetry systems as long as we are headed this way Is the www.sm-modellbau.de system.It uses data-logger system with a 2.4Ghz RX/TX radio communication.They offer a long list of component sensors and live view data-logger screens.They offer USB programming and even offer a GPS, temperature , RPM , battery everything , barometric , G-force and speed sensor.
A good source of programmable ESC/Data-logger speed controls are Castle/Phoenix.They do offer a programmable reverse/forward option.http://www.amainhobbies.com/product_info.php/cPath/2_389_416/products_id/10268/n/Castle-Creations-Phoenix-HV-85-High-Voltage-Electronic-Speed-Control
Hope this helps anyone Interested In the latest gizmo.
Regards,
John
Regards,
Giovanni
