PROBOAT RECALL 17
PROBOAT RECALL 17
I put a bigger battery in which increased the running time but it did have detrimental effect on speed and😁 handling.
Quick way to check if a larger battery will affect performance is to weigh the existing battery, note weight then find out the weight of the bigger battery you intend to purchase.
Make up some ballast to the weight difference between the two batteries and put it in the boat with the original battery and see if there are any changes in performance as a result.
It will save you buying the larger battery if you feel the performance is less than what you expected.
Boaty
PROBOAT RECALL 17
I suspect the higher capacity will make for some interesting sailing so you may need your bike clips!
There could also be a heat problem so do check the motor esc after a short warp speed run.
Please post progress
PROBOAT RECALL 17
If you mean a higher capacity then the answer is yes. However there may not be room for a larger capacity battery and in a small model it may be too heavy for the hull.
Can you post some pics of the installation and advise the actual capacity (eg 2200mA)?
PROBOAT RECALL 17
Sorry. It's a Proboat Recoil 17.
Aimé par
Chargement…
