motors
motors
Re 'Diversion' - according to the German Motto 'Spaß muss sein' = Fun must be 😉 Especially the week before Christmas,
Have a good one everybody, best wishes Doug 😎
motors
(apologies to pilot for the diversion from his thread)
motors
motors
motors
motors
motors
motors
motors
motors
4-1050kv water cooled brushless 160a water cooled esc thank you all for your help steve
motors
motors
and found a dymond gtx-4356v2/600kv outrunner.
could i use this on my huntsman 31 if i can how would i cool it
need to get this sorted
motors
That size plus a kv figure of around 700 to 1000 will provide plenty of torque to get it moving and high enough revs to get it on the plane.
Once you start getting a kv figure well over 1000 you start to get into higher revs which is useful for smaller batteries (e.g. 1000kv x 7.4v = 7400 rpm) which as said is good for fairly small, light, sports and race type boats.
Conversely if you have quite a big displacement boat then you want quite a big motor but with a low kv figure as you don't generally want to tear along but want torque!
motors
Is this the better motor to use? if so, why?
I use brushed motors, but wish to know about brushless.
motors
Either would do the job but the higher kv one would be a little better.
Again as Canabus says the smaller high kv motors (well over 1000kv and therefore high revs) are more suitable for light very fast craft.
motors
ChrisF is about right with the overland, but, if it's Hobbyking stuff.
A Turnigy L5055C-700kv 1600watts on 4 to 6S with a 100Amp ESC which will handle up to 6S.
I am starting with a 2blade 52mm CNC prop(377000019) on 4S.
The 3674 1900kv is more for a high speed race boat.
Canabus
motors
Have a look at AIRTEC, they are a UK (Yorkshire) based model shop and have a good range of their own motors
motors
You want good speed but not manic.
The one you mention is an inrunner brushless which doesn't have as much torque size for size as an outrunner.
If it was me (and it will be at some stage as I have a 46" Huntsman with an MFA 850 brushed motor in it) I'd be looking for a 50 diameter outrunner around 700kv which will give plenty of torque.
There is a Turnigy just under that which might do.
I'm building a 33" Swordsman and am fitting an Overlander Tornado Thumper V3 4250/06 800kv outrunner. it is probably a little oversize but my thinking is that the motor will have an easy time, run cooler and the battery (4S) will last longer. if it is too fast I'll limit the throttle. Better to be too big than too small in my book.
Overlander do a 5045/10 720kw which should be good on 4S which could always be increased to 6S if necessary.
See what others say though.
motors
turnigy xk3674 1900kv part number 9393000021-0 and
turnigy marine 120a bec waterproof speed controller
part number 9020000033-0 what do we think steve
Aimé par
Chargement…
