Chine Spray Rails
Commencé par Will-I-Am
2 répies 1 aimer 0 abonnés Dernière activité : il y a 8 ans
Chine Spray Rails
Hi William,
First; it looks like the rail was not fitted according to plan🤔
However; my Sea Scout has no rails at all (Yet!) and as you have seen in your other thread on this topic she runs fine with the same profile rudder.
BUT; I notice that your rudder extends well below the prop. Mine only to about half way down the lower blade and she's very responsive with no sign of digging in.
Before messing up a nice hull I would trim the rudder back to at least the lowest extremity of the prop. Do another sea trial and if she still digs in a bit lop a bit more off, to about half way down the lower prop blade. 😲
Easier to mess with the rudder than with the hull 😉
Aimé par Donnieboy
Chine Spray Rails
Spray rails tend not stop heeling, on tight high speed turns they will dig in causing a heel, you could fit adjustable stabilisers on the lower transom like on racing boats. Cheers Colin.
Chine Spray Rails
I have a modav Huntsman 31, which heels over quite a lot on turns even after slowing down. I was looking at the chine spray rails at the rear of the boat (see picture) they do not dip below the outgoing angle of the hull as shown on the plan (see picture). Would a triangular fillet located under the existing chine strip to simulate the plan for a length along the hull from the transom improve the heeling over in turns?
