bulkheads
Commencé par green72west
7 répies 5 aimers 0 abonnés Dernière activité : il y a 8 ans
bulkheads
The first pic that Green has posted, does show a 'Schottel' drive unit at the left of the plan, no wonder he is confused.
Aimé par RNinMunich
bulkheads
The plan at the top of the thread shows a specific Water Tractor tug plan specifically designed for the VS drives, including the large straight keel at the stern. I suggest Green72West should either use VS drives or use another type of hull for Schottel drives.
Aimé par RNinMunich
bulkheads
Hi Gerd, it's not my plan!
The plan is from 'green72west' who started this thread and seems to be confusing Schottel and Voith-Schneider. Either that or he wants to use two Z-Drives instead of the Voith drives. His intention is not clear. Either way he doesn't need to cut chunks out of the keel, that's nuts😲
bulkheads
Hi Haig, seems to be a common mistake to get Schottel Drives (Z-Drives) and Voith - Schneider confused with one another!
First two pics show a twin Voith propeller on a tug hull (as on the plan above) and the operating principle.
3rd pic is cross section of the Z-Drive as produced by the Schottel company. it is a 360° rotating 'pod'.
Newer versions have electric motors built into the pod and don't need the mechanical Z transmission from inside the hull.
With such pods under bow and stern even bow and stern side thrusters are redundant 😊 4th pic is the Graupner version, Mk II.
https://www.graupner.com/Schottel-Drive-II-new-version-/2335/
Aimé par reilly4
bulkheads
Why do you need Schottel drives? The Voith Schneider drives in that configuration can move the boat in any direction? Schottel drives will require fairly big penetrations through the hull, and apart from the installation complications, should (in my opinion) be unnecessary.
This is a link to a fairly comprehensive brochure with photos of the real thing that will help in understanding the concept etc. http://www.gemimanevrasi.com/Tug_Boat_Technology/Voith%20Water%20Tractor.pdf
Aimé par RNinMunich
bulkheads
I have hopefully posted photos of stern/bow shape of bulkheads
+ side view of the hull. there are 20 frames in the hull. how can I
install x2 graupner schottel [2335] at the bow. I will have to leave
out the keel under hull. thankyou Green. the plans are 1/50th
scale.
R.SHAW
