motor sizeing
motor sizeing
I used a Hobbyking D3548/4 1100kv , a car ESC (hk60A-SL)(electric fan on top for cooling), program card(HK PROG-CARD) and a 40mm 2blade prop(test out the one on the boat first).
Battery a 3s 5800mah 30C Lipo.
This is in my Sea Commander and gives a good turn of speed with a long run time.
ESC set up:- 1 Cutoff Voltage for 3S=10.2 and 4S=13.6
2 Start Power Percent=5%
3 Advance Timing=4
4 Run Mode=2
5 Brake Force=1
6 Drag Brake Force=1
7 Neutral Range=1
8 initial Brake Force=1
9 Reverse Force=1
Canabus
motor sizeing
a prop size how is that worked out for a boat.
Aimé par
Chargement…
