Styrene Allergy?
Styrene Allergy?
Don't forget to Blog the build!!
I use Contacta as well, good stuff.
Styrene Allergy?
Nerys
Styrene Allergy?
My chum works a vac-former to make model car glazing and he thoroughly washes every sheet of PVC before forming it. Stops micro-bubbles forming.
I use blue nitriles when epoxying. I always found latex melted on contact with most of the things I used, like enamel paint, Marineflex, etc. Nitriles stay put.
Styrene Allergy?
Styrene Allergy?
Not being affected (like Granny used to say "No sense, no feeling"!) I hadn't considered that and never 'eard of blue nitrile!
Would be interesting to know which glue Nerys is using!
Would also recommend that she washes her plastic stock with washing up liquid, to remove any possible residue from the production process, before starting to cut it.
Cheers, Doug
Styrene Allergy?
Don't know about you though, but I can't breathe in any mask worth it salt. I just do it all outside in the almost permanent breeze that blows round my bungalow. I stand in the doorway of the shed and spray out into the great blue yonder.
Styrene, fortunately doesn't affect me. When Slater's first popularised Plastikard, old man Slater used to demonstrate the making of things like model house window frames with Micro strip and Slater's own solvent called Mek-Pak. The smell was glorious and just oozed quality modelmaking to me. I always made a bee-line to Slater's stand at any suitable exhibition. These days I use Plastic Weld as it does more plastics than just styrene and it doesn't have that lovely "esterish" smell.
Styrene Allergy?
So I repeat, good ventilation, extractor fan, thin latex surgical gloves and a face mask as one should also use when spraying. Cheers, Doug 😎
PS Sell that kit and buy something friendlier!😉
https://www.wikiwand.com/en/Styrene
Styrene Allergy?
It may be advisable to ask your gp for a skin allergy test.
Styrene Allergy?
Once a CA Glue sensitivity develops, it is difficult to overcome.
Try masks; try good ventilation.
Even when cutting Styrene, ensure You have good ventilation.
Styrene Allergy?
Fair winds,
Nerys
Styrene Allergy?
I use silver solder (hard soldering) all the time and have done for over 50 years, most of it with cadmium rich (still, I get it from ebay) and I have had no unpleasant reactions. OK, currently I have the shed door open as it's a very small shed, but I never used to in a 7x5. Before that the space was always bigger. Cadmium free modern silver solder is crap as it will not flow as well as Cadmium containing.
Styrene Allergy?
Cheers marky
Styrene Allergy?
I think I'd just put up with it as I couldn't stop modelmaking even if I wanted to. I did painting when we lived afloat for lack of space, but I didn't find it satisfying enough.
Styrene Allergy?
Styrene Allergy?
Styrene Allergy?
You have to ask yourself. is it the Styrene or is it the glue?
Why don't you try using surgical gloves!
Non allergenic gloves might help.
Give it a try and see if this helps!
If not you might have to stop the build.
Until you figure out what your allergic to!
Hope this helps....
Cheers, Ed
73
Styrene Allergy?
Regards,
Nerys
Aimé par
Chargement…
