Videos
Commencé par Westquay
20 répies 17 aimers 0 abonnés Dernière activité : il y a 8 ans
Videos
For what it's worth folks (by popular request😉) I just posted the pdf reading/downloading instructions in the 'Anything Website Related' forum.
C.U. Ciao, Doug 😉
PS Also applies to other files attached to Posts, such as photos!
Sometimes you can also expand the photos to be able to store them in a higher resolution! 😉
Aimé par reilly4
Videos
Hi Haig, if i had such Administrator rights I would gladly add such a section!
I'm just a 'Bod' like you!
Reading PDF files is definitely one of THE most asked questions!
Best I can do is post the instructions in the 'Website related' forum.
But who looks in there!?
All's well ....!
Aimé par reilly4
Videos
Hi Doug,
Thanks. I can download and see a 'save as' as an option. I have not come across your previous explanations but that's my fault.
Maybe the website can have an FAQ section with these explanations.
Aimé par RNinMunich
Videos
Did it work for you Haig?
Videos
Shouldn't make any difference John!
The 'Save or Open' Window box (!) comes from the operating system of your device. The box includes an 'Open with' option drop down box which displays the PDF handling programs available on the device.
What are you using? PC or Dumbphone?
PS Nuance is NOT free like Adobe Reader, but much better 👍
BTW; if you install Nuance Power PDF and uninstall Adobe Reader all your pdf files will automatically be opened by Nuance!
Videos
No not getting the save/open commands😭 I have loads of stuff on Adobe. Can I move it to Nuance pdf ?👍
Aimé par RNinMunich
Videos
Oh dear oh dear oh dear!
How many times have I explained this 😲 (So often I copied the text into a Wordpad file 😁)
All you have to do is
Just left click on the Adobe icon so the Media Gallery opens with the larger icon.
Left click on [Download], top left corner of the media gallery window.
Windows will then ask you if you want to Save or Open the file.
left click 'Open', your pdf reader will open it. You can then save it to wherever you want.
If you are using a 'Dumbphone' - I don't know🤔 I don't!
BTW: I use Nuance Power PDF, much more versatile than Adobe and without the security weaknesses!
Aimé par AllenA
Videos
Doug why can't I open your adobe images? I have adobe.👍👍👍
Videos
H Martin, sorry it took longer than expected got bogged down in other things🤔
Sooo! Scouring the docs I could find (see attached PDF files) I was surprised not to find the usual table of Number of photos or video length vs memory available!
Anyway two significant statements I did find-
1) "Movie length - up to 29 minutes"
When I see 'up to' I read that as with the lowest resolution, in this case 640*480 pixels. Which you can forget; tha's like a 20+ year old PC and worse than the old UHF 605 line TV pictures.🤔
2) "Movie resolution -1280x720/ 30fps (HD).
Now that's more like it😊 BUT: in the manual I then found-
"The option FHD and HD only available when a Micro SDHC class 4 or higher speed class card is inserted."
Soooo! get yourself a 32GB (not sure if a 64GB card will work!) memory card SDHC class 4 and awaaaay you go 👍
BTW the internal memory is only 64MB so you can forget that for video. Seems only to be used for storing user settings (made in the camera menu) and a few photos. I recommend using only the memory card for photos and above all videos.
Happy shooting Mr Director,
Cheers Doug 😎
BTW: '720p' just means 720 pixels (Picture cells) vertically, using Progressive scan, as opposed to interlaced.
Thought you might like to know that 😁😁
Videos
Same here Martin drizzle all day. What they call here 'Kuschelwetter', cuddling weather! 😉
Forecasted to remain so through Monday, then we start getting warm winds from italy again. Temperature back up to 20°C by Friday😊 You may remember the Föhn wind from your time in Sauerlach.
Still, managed to get started with the preservative on my fence posts.
Mounting will have to wait until Thursday or Friday I expect.
More info tomorrow when I've dug a bit deeper into the partly contradictory Praktika docs!! Cheers, Doug 😎
Aimé par doghouse
Videos
Thanks, Doug. Peeing down here, so I epoxied the cracks in my lovely old just post War Ailsa yacht indoors and put it in the heat of the boiler room! We'll see how that goes tomorrow. Grotty old day all round now. Curl up weather!
Aimé par doghouse
Videos
Hi Martin,
OK, I've found the manual and an extended data sheet.
Will digest that and get back to you tomorrow.
Gotta go and finish making new fence posts now! 😡
'Be prepared', 😉 Doug
Aimé par doghouse
Videos
Morning, Doug. What a gent and a Boy Scout you are, sir. This is all new to me. My old video camera was just that, a video camera as of old. Perfectly fine till the batteries died and then I could only use it on the power pack indoors. it looked like a cine camera!
This is a Praktika Luxmedia WP240. it says it has HD video, 720p on the box lid, whatever that means!
Thanks for any help, old chum.
Aimé par doghouse and RNinMunich and
Videos
Evenin' Martin,
Forget the Mbps (Megabits per second), what counts is the resolution of the photos or videos that you take. The higher the resolution (more dots per picture or Frame in the case of video) the more 'dot' information has to be stored = more memory and a faster Mbps rate are needed.
Not to mention the number of frames per second, FPS; you film at! Anything over 25FPS fools the eye and the brain into 'seeing' continuous movement. very high frame rates, up to 50FPS, are only needed if you are filming F1 Hydroplane races or similar!
Sooooo, higher resolution or frame rate means shorter playing time for a given amount of memory, i.e. your micro card. in the camera menu there will be a point in the Video section where you can select the resolution. HD is best !!
Set the camera to HD (or Fine) resolution, record a 5 or ten minute video and check how much space you have left on your card.
Most camera displays will give you this info in terms of 'Time left' at the set resolution. My Sony and Pentax do .
Again, give me the camera make and model and I'll see if I can find this info on the manufacture site.
Bon chance mon ami, cheers Doug
Most cameras also have some fixed internal memory as well as a card slot, with a corresponding Menu point where you can choose where to store your photos or videos.
There is also usually a section in the manual describing the video function and a table of resolution settings versus how long you can record with a given memory size.
These days the User Guide supplied with the camera is often very rudimentary and you are invited to download the full Monty manual from the manufactures website. The 'User Guide' should contain this web address.
Give me the camera make and model number and I'll see what I can find.
Aimé par doghouse
Videos
Hi, thanks. No idea what Mbps are or how to change them from one to another, but 40 minutes is plenty to just record bits of boats afloat. I've often wondered about a youtube channel showing people how to make stuff. My 11 year old grandson lectured me on it yesterday! "You'll need a decent camera with a tripod, Grandad", he said knowledgeably, "and a mike and you need a nickname and an intro and an Outro" He wasn't impressed when I joked that that was a track on a Genesis album.
Aimé par doghouse
Videos
Hi Westquay,
Maybe this'll help
8GB
Recording speed
24 Mbps 40 min
8 Mbps 120 min
Cheers, Ed
"Fair winds calm Seas"
73
Aimé par doghouse
Videos
Don't have a direct answer but would suggest you check the instructions and find the max card size you can use. A 64 card would pretty much cover anything you wanted to do and they are not expensive.
Aimé par doghouse
Videos
Hi, I have a new camera thanks to my dear bride and it takes video. What it doesn't say in the book is how long a video one can take. It has a micro 8 GB card, so how long could I video something? Anyone know?
