Being Sociable.
Stephen.
Being Sociable.
Being Sociable.
Thanks for the comments.
The ribs or frames are of "bent" construction, steamed then bent around former's, left for a week then the laminates glued together, a method that with the benefit of hindsight i would not do again, however it does produce a very light and strong hull, add to that I decided to make the entire deck + bulwarks including the last few strakes removable in one piece. This was not initially planned and turned out to be very frustrating, though I am now happy that I made the effort. Please find attached photo's.
I have a copy of Tree to Sea and it is brilliant.
I have looked at photo's of the excellent John Hemmings kit.
Your trawlers look great, are they steam powered?
Stephen.
Being Sociable.
Being Sociable.
Love the detailing, esp the plating and riveting 👍👍
A LOT of time and effort has obviously gone into these
'A labour of love'!
All they need now is some crew😉
All the best, Doug 😎
Being Sociable.
Being Sociable.
But we get there in the end - don't we? Quality takes it's time😉
Happy steaming,
Doug
Being Sociable.
Hadn't thought of powering the work boat....
Sea trial video may be years away, this build moves at a Glacial pace.
Stephen.
Being Sociable.
As a dumb electronics man I'm envious of your skills.
The clinkering is superb.
Does this mean that the oarsman is steam powered? Novel!😉
I've been doing some research on a rowing mechanism using a small electric motor.
Would take me two months of Sundays and bin fulls of false starts to get anywhere near an engine as sweet looking as yours. Hat off Sir👍
Looking forward very much to the sea trial video .
How about a build blog? As inspiration / instruction to we lesser mortals!
Wishing you always a full head of steam, Cheers, Doug 😎
Being Sociable.
My apologies for not seeing your post earlier, I don't log on very regularly, preferring to spend as much of my spare time in the work shop.
I am interested in marine steam as well and currently I am building a model of Formidable, LT 100 from John Pottinger plans enlarged to 1:24th scale. I have built a double acting, twin cylinder oscillator, steam is to be supplied using a steam generator otherwise known as a mono-tube boiler. Control being done using a Taranis 9xd programmable radio, quite untested at this stage.
I have added a couple of photo's.
Stephen.
Being Sociable.
Very generous of Gary, hat off to him 👍👍
Would still like to see his promised refutes to my queries though.
Being Sociable.
Can't wait to see your new acquired steam engine!👍
That was very generous of Gary!
Now you will be bitten by the steam bug...…
Cheers, Ed
73
Being Sociable.
Gary once again many thanks for your encouragement and generosity. I will be in touch by email please confirm your email address, you already have mine so drop me a note.
Being Sociable.
The rudder is controlled by an electric motor, NOT a servo, so you have to return the motor to central after a manouevre, so you have to think well ahead of where you are, and where you want to be!!
Being Sociable.
Being Sociable.
I have yet to check out your web suggestions but I am keen to look and hopefully find something of interest. I will share with you my only dealing with steam, As a boy of 13yrs I transformed a Mamod static engine (SE1) to fit in a 36" yacht hull, needless to say it wasn't a pretty sight but it did work, in a fashion.
All the best Michael
Being Sociable.
Being Sociable.
Being Sociable.
Being Sociable.
Your curious response to my post prompted me to look back at your history.
In your very first post on the site four years ago I ran across this about a tug project of yours -
"My reason for trying to build this particular kit in the first place, is it is 39 inches in length with a beam of 10 inches, with a one piece large superstructure making it ideal for a steam engine."
All very fine but it underlines the snag many of us have, especially naval modellers with 10to1 LoA / Beam ratio, that we simply don't have the beam and superstructure height necessary for steam power plants.
Regards, Doug.
Being Sociable.
If you wish to start a Steamer thread then why not title it as such?
In no way did I wish to be AntiSocial.
I simply responded to your somewhat provocative question, which I quoted in my previous post, as did several others on the site in similar vein.
Whilst I admire those who can build steam engines, and I have done that on this site, I simply listed in my response to your (perhaps rhetorical question?) the obstacles that most modellers are faced with when it comes to steam power in models.
Perhaps I should have added number 7. -
For most of us the SHIP is the main objective and not the power plant which in the vast majority of cases is hidden under deck.
If steam is your THING - GREAT I have no problem with that. More power to your boiler 😊
It just won't work in my ships and boats. Esp. my subs 😉
And I don't have the patience for all the faffing about necessary to get going at the lake - one of my six points mentioned above.
And I suspect that goes for many other contributors to this site.
My post simply consolidated several similar responses from other members.
You write; "I could correct all six points that you felt you had to share ..."
I would be MOST interested to read your refuting of ALL my six points if you have some valid arguments.
Throughout my professional engineering life I have always been open to alternative ideas and solutions. So prove me wrong and uncross my wires please. I look forward to your point by point refutation.
BTW; as an experienced electronics engineer I always carefully double check my circuits before applying power - so crossed wires are not normally a problem with me. Similar principle also applies to my considered response to your posts.
Regards, Doug 😎
PS: did you build your steam engines or buy them?
There are some guys on this site whom I admire very much, but can not emulate, who build their own.
PPS: Quote "In the fifty years or so I have been involved in this hobby I have NEVER ever installed an electric motor in a boat."
Fine, if that's your THING, does come across as a little fanatical though.🤔
Being Sociable.
Being Sociable.
1. Cost.
2. Space available in the model.
3. Complexity of the engine and difficulty of control.
4. Fire risk, and not just to the model.😲
5. Shorter run times, longer 'steam up' times.
6. Unsuitabilty for many types of ships / boats. I.e. originals weren't steamers.
If I read above posts correctly I thought you had already found at least two kindred spirits here.
I'm sure that if you take the time to cull throught the hundreds Build Blogs and technical Posts here you will find others. Try using the Search function. See the panel on the left of the Home page.
Good luck,😎
BTW: Nobody likes a fanatic! Don't get steamed up 😁
Being Sociable.
But, one is cost the other would be.
The Brooklyn is all Plastic!
Now really have you looked at the prices!
Talk about sticker shock!
And for that reason.
I use electric motors!
But for those fortunate to be able to get steam engines.
Enjoy!
73
Being Sociable.
Joe
Being Sociable.
Just a quick search sees prices of a complete installations in the region of £1500 -£2000
Being Sociable.
Cheers Marky👍
Being Sociable.
Being Sociable.
It is snowing here and I'm hold up thinking of what I will need for my steam engine assembly.
Pipe sizes and fittings and thread sizes and the one thing I forgot to order was the fly wheel so I'm going to order from the site I got the engine from do you know of another spot I might look to get a fly wheel .
Rick
Being Sociable.
Being Sociable.
Good to hear from you the bench work is still on and yes it will run longer on the bench than on the water but for now it's good to see the plant run.
Your idea on the shut-off is good I'm still researching.
Regards Rick
Being Sociable.
Being Sociable.
You kick started my memory as well!👍
A few years ago I was astounded to find some repros, also made from Coke tins and the like, in a flea market. So I bought a few. Gave most away as presents and just spent half an hour fruitlessly looking for mine. 🤔 Guess it'll turn up when I'm looking for something totally different.
It used slow burning tablets about 2cm diameter as I recall. I have no idea where I can get such things these days.
I'm currently trying to sort my stash of kits and materials to reorganise the workshop so I can find 'stuff' quickly and get some projects finished at last!!
TOO MUCH STUFF😲
Cheers, Doug
Being Sociable.
I have also seen a larger one of these in a 1940s book like "The Boy Mechanic," where copper tubing was used for the "boiler." The two ends of the tubing were directed aft at a shallow angle, just like stuffing boxes, and the middle of the tubing was would in a coil with three to four turns and supported so that a can of "canned heat," used for keeping chafing dishes hot, could be inserted under the coil to generate the steam. if I recall correctly, the two ends (steam pipes) have to be bent so they are both a little higher than the bottom of the coil to avoid having all the water drain out immediately. if I find that book I will post any drawings they have.
Being Sociable.
I have been interested in steam for a considerable time, and even have an article stashed away on making a turbine for a model of the SS Savannah, which is, after all, a steamship with a nuclear powered boiler.
My own work has been limited (mostly by budget) to the Midwest Models single cylinder steam engine, and I have a "Fantail Launch" kit ready for some upgrades and installation of the steam engine. Stay with us, as I am sure, as already stated by others, that there are interested members of the forum, and you will pick up more when they see you are not just talking about a little pop-pop boat running in circles. (I do have one of those, as well. I had one when I was much younger, but it is little more than a memory these days.)
Being Sociable.
Rick
Being Sociable.
Being Sociable.
Rick
Being Sociable.
Being Sociable.
Aimé par
Chargement…
