hull trouble on vintage yacht
Commencé par jacko
11 répies 7 aimers Dernière activité : il y a 8 ans
A man's gotta do - What a man's gotta do! 😉
Good luck Jacko🤞
Aimé par jacko
Thanks for all you advice and help looks like its a re strip and a coat of EzeKote and then more painting as i am trying to do a vintage i like to do things that they did when the yacht was first built back in the 40's
Aimé par RNinMunich
Aha! See what you mean👍
Agree, that wouldn't be advisable at all🤔
Well Doug, I also have done it hat way before painting. But it seemed like it was being advised as a top coat sealer. I always use Eze-Kote now on all the vintage refurb.
Aimé par RNinMunich
Why would that be Colin?
Suitably flattened off with wet n dry and then primed there shouldn't be any problem!
At least I never had any.
Mind you, I personally prefer to use the Deluxe Ezekote (Ezecote?)
It has several advantages over epoxy:-
One part so no messy mixing
No rushing about if you put too much hardner in😮
Water based so no 'orrible pong and no rock hard brushes😆
just wash 'em out with warm water😉
Dries and can be sanded and primed in 20 - 30 minutes.
That's what I've done with the wooden hulls of my Sea Scout, fish cutter and PTB and it's worked a treat.
Hi Mervyn, yes that is a possibility but not very pretty as the paint will be distorted by the epoxy. And such a beautiful boat deserves to be done properly.
Suggest you cote with fibre glass resin. The resin should seal the hull.
Mervyn Pollitt
South Africa☹️⚡.
Suggest you coat with glass fibre epoxy resin. This resin should seal the hull.
Mervyn Pollitt
South Africa
Hi Jacko,
Colin's dead right I'm afraid🤔
If you only seal the inside, to stop water entering the hull, water can still soak into the wood from the real problem outside. The wood will then start to rot!
On my fish cutter I used EzeKote (Deluxe Materials) with FG tissue on the inside.
The several coats of Ezekote on the outside.
I had previously found any leaks or weak (thin) spote in the hull by shining a bright light inside it. Good luck🤞
As you have already painted it will be hard if not impossible to seal. Unless you can pinpoint the leaks. Check for any cracks in the paint, and the rudder post entry. Really sorry but you may have to strip back the paint to bare wood and seal with resin and 0.3mm glass cloth before repainting. Hope you can sort it as it looks a fine model.
Aimé par jacko and Donnieboy and
have you thought of using resin. both inside and out if required.
Aimé par MatMch
hi all as you know I did a refurb on a vintage yacht and have been sailing a few times but this week after a few hours sailing i looked inside (HORROR) ingress of water the hull was striped and sanded and under coated then 4 coats of Humbrol Enamel what can i use over this to seal the hull
