34" fireboat restoration
Peter G
I would satisfy individual requests via email if I had the data to hand. Unfortunately, I only have the Sea Queen and PT Boat in computer readable format and, annoyingly, can't find the paper copies of all the others.
You might like to note that the South African Model Products range were very similar to the Aerokits range - essentially copied. They are not original Aerokits, but if you want a small boat which is very similar in construction they would fit the bill. See http://oldboats.tk/ModelProducts.html
Sea Urchin
Peter G
I sent the frames and plans as PDF.
If you email me at
harrysmith2@dodo.com.au
I will send them direct.
Note for gmail the files are too big !!!
Canabus
I have the plans and frames of the Sea Hornet.
I have built boat and it's a rocket !!
28mm brushless 1900kv on 3S with a 2 blade 30mm prop.
GPS at 45KPHour!!!
It would be better at 25% bigger to get your fingers inside to work on.
I have the Vintage Sea Commander plans with frames, but, I did not build the boat.
I brought one made, ran it for six months and swap it to a very nice Hellen fishing boat.
The Sea Commander is a smaller version Of the Sea Queen.
Canabus
Yes I still have the plan.
Have you have any plans.
Canabus
Do you know of a supplier?
if you look up vintage model workshop they do the window fittings for the 46" fire boat.
They also make the full set of fittings as well as the tranfers for it.
http://www.vintagemodelworks.co.uk
Many thanks
Looks quite good on the water, bow well up and planing, have you put in water cooling for the 600 motor and ESC?, as I originaly used a graupner 600, without cooling it, and it cooked really well!! I find when using LiPo's, it is worth cooling the whole system, or at least keep a check on the heat build up.
would just like to say that Jon is the genius behind the fire monitors, power, and wiring, I am sure he would help others if he can.
As to the colour we tried to bring it up to date as with some of the equipment as it has flashing blue lights, siren, also working monitors, surchlight, nav lights, etc however I did not have chancce to see the paint for the deck dry to see the finished look so things may change , there seems to be as many coloue scheams as there are boats.
Kev
Like your scratchbuilt monitors, you will have to market them for other members to buy. Unusual colour scheme for the fireboat, it that your own idea? or have you seen one in that colour format, what are you using to power your boat? I am in the process of rebuilding the 34" and a 46" fireboats, I tried out the power selection of the 34" last Sunday, a brushless 2700KV motor witha 11.1v 3cell Lipo, and a X35 prop, WOW! difficult to keep it in the water, could not try full power, to fast and you really have to think about turning, and drop the speed or she would overturn, will post photos of both builds and running when time permits.
Yes, you could try the Robbe or Graupner foam/water monitors, but they are not correct for scale or period, they are for mainly their own boat kits, White metal is fine, and very original to the Fireboat kit, I have never found weight a problem.
I have been putting a dash of sorts in and its now in primer. more to comeas and when.
All the best Kevin
is your fireboat the 34" version? if so there are a set of white metal fittigs available
from Model Slipway. They are fine if you are modelling the boat No:94, but if you want to do No:93 boat, they are the wrong foam monitors, hope this helps you.
Looking good.
The original Aerokits plan is not very accurate in the detail shown. More of a general arrangement plan to show where the fittings should be placed. There was a kit of castings produced but no longer available. See pics 😊
The Plans and Docs section on this site gives much more detail and I suggest this is a suitable starting point. 😀
The fire monitors and window frames have been described in detail in past Forum posts and whilst some may refer to the larger version the size can be calculated.
I helped a friend sell a complete kit recently and attach the photos taken at the time. He also sold a larger version and the pics are of this model. Probably not all the correct fittings but hopefully a starting point.
Good luck with the restoration, and please keep posting the details so others can share your experience. 😀
Aimé par
Chargement…
