Mtronics ESC's
Abonnés (6)
- RookysailorSilver
- mturpin013Bronze
Mtronics ESC's
Peter(Rooky)
Mtronics ESC's
In the UK QC can mean either Queen's Counsel, a very high ranking lawyer / advocate, or Quality Control. 😉
Mtronics ESC's
No, Quality Control!
What it called on the other side of the pond?
I just made Rear Admiral!
And I'm already in trouble!!!!!☹️😜
73
Mtronics ESC's
So, What about QC?
What ever happened to QC?
73
Mtronics ESC's
I use 15's in all my models!
But, I'm only pushing 5 amps
Haven't had a burnout yet!
Cheers, Ed
73
Mtronics ESC's
No question is silly or Daft.
PCB is short for Printed Circuit Board.
Mtronics ESC's
Whilst several of the Quicrun features are of limited value to us ship modelers the reliability and cost appeals. If others have not tried them they are worth considering. Only issue I have found is the wires are a little short.
Mtronics ESC's
I spent eight years making PCB's using surface mount machines and have placed millions of components.
Also tested millions of PCB's and I know that although a few fail most pass.
But we still got a few sent back due to failures.
I also know that a few PCB,s that failed the first test were tested several times and then passed.
I even know that some had a lot of failures so the company that we tested them for chanced the programs so that they passed.
Even changing a component to an equivalent made a lot pass the tests.
And to make matters worse because of the large volume of PCB's for certain companies they decided only to test one In twenty, so purchasing any electrical products is a bit of a gamble.
Mtronics ESC's
I have had a reply from mtronics apologising, but not identifying any specific problem. They will replace the damaged unit however.
Thanks for the heads up on the Quicrun. I now remember I fitted one to the outside of an airboat, so it's open to the water. No problems. I was also impressed with the packaging , instructions and fittings that came with it. My next purchase I think.
Mtronics ESC's
"The Hobbywing Quicruns are great, ... and you can set the parameters of brake, no brake, lipo or nimh with jumpers instead of doing the transmitter throttle stick 2-step."
I can't dance ☹️ so I used the little programmer😉
Since they are 'out of the box' set up for cars the first thing to do is switch off the Brake between forward and reverse!
On mine it is also possible to set soft or hard (scalded cat😮) start!
Mtronics ESC's
The Hobbywing Quicruns are great, I have 3 of them, never a problem, and you can set the parameters of brake, no brake, lipo or nimh with jumpers instead of doing the transmitter throttle stick 2-step. I have some Turnigy Plush brushless escs that I use if I don’t need want reverse, and I bought a program card to suit. Beats the living snot out of trying to program with the transmitter.
Mtronics ESC's
"Have had a couple or so Mtroniks ESCs fail with burning smells and wires coming out.
Then started using Quicrun ESCs available on the Internet. They are cheaper and perform well. Now have 4 in service without any malfunctions. "
I have a few Mtroniks Marine 10s for my smaller ships, one per motor, and so far no problems🤞
On the other hand! I also discovered the Quicrun series.
Initially for brushless for my Sea Scout upgrade, where it works perfectly😊
I didn't like the prices of the Mtroniks Tia Brushless series!
Then I found the dual brushed Quicrun which I haven't tested yet but I expect it work just as well in my destroyer.
All the recent reports of very similar failures makes me wonder if they've changed the output circuit, e.g. different FETs. Maybe they caught a dud batch of FETs which can't stand the heat!!
Mtronics ESC's
here is a link to the whole discussion: https://www.rcgroups.com/forums/showthread.php?3262185-ESC-suggestions-Tug-boat
good luck
STEVE
Mtronics ESC's
The started using Quicrun ESCs available on the Internet. They are cheaper and perform well. Now have 4 in service without any malfunctions.
Mtronics ESC's
They won't acknowledge receipt and won't let you know they are sending replacements.
The replacement will just arrive eventually, without any paperwork.
Mtronics ESC's
In fact, Phil has had two of the same esc's fail in the last couple of months. The first one popped out a negative lead, as mine did, but did not smoke. The second one was switched on but not under load and suddenly started spitting bits of molten plastic out and smoking badly.
I will contact Mtronics and let you know how I get on.
Ps, mturpin, where did you stay?
Mtronics ESC's
Good look
PS just been on holiday near your location, a nice part of the country
Mtronics ESC's
Just recently there seems to be a few now that have burnt out or have just gone pop.
I am wondering if there has been a change in the manufacturing process.
It could be a good question to ask them!
Mtronics ESC's
I hope you are OK!
And you didn't burn your finger too much!
I never seen one of those ESC burn up like that.
Maybe you should get in contact with the Manufacture!
To see what they say.
Maybe they'll replace the ESC!
Cheers, Ed
73
Mtronics ESC's
Having switched on the transmitter, I switched on the port esc. The motor revved very quickly and smoke billowed out of the boat.
I pulled the plugs and through the the smoke screen burnt my fingers on a melting esc. The negative power lead had been pushed out.
Any thoughts gentlemen?
Aimé par
Chargement…
