Getting stern right
Commencé par Ronald
30 répies 65 aimers Dernière activité : il y a 7 ans
#31
Getting stern right
Sounds good Ron,
Look forward to you'r future updates.
Aimé par Rookysailor
#30
Getting stern right
Thanks Martin. I called the owner today, and he said the original plan was to have a sliding door on the wheel house sliding aft. It would have a rectangle window in it too. I will put these on the wheel house shown closed, as the wheel house floor on the model is partially open for the battery. A pilot wheel is to be installed and a skipper.
Aimé par Martin555
#29
Getting stern right
Hi Ron,
She is really starting to look like the photos of the real thing.
Well done.
Getting stern right
Looking good Ron - suggest you try to find the metal (aluminum?) clamps (like the blue ones) - seem to be better made and much stronger than the plastic ones. Make sure you get the ones with the big foot though - the thin ones tend to dent the material. Definitely last much longer than plastic . Been using mine for over 10 years now - unfortunately on commercial jobs too! Does interfere with ones hobby time.........
Aimé par Martin555
#26
Getting stern right
Never enough clamps. Those alligator type loose their strength after a year. And the blue ones loose the swivel foot. Time to find a sale.
Aimé par MouldBuilder and RNinMunich and
Getting stern right
Will add some ballast over the keel area & under motor, around universal, stuffing box. Just to keep it from rocking when under power.
Aimé par MouldBuilder and Martin555
Getting stern right
I used tapered balsa to get a slanted deck. The sub deck will strengthen the model before the basswood decking. This tugboat has a steel plated deck.
Aimé par mturpin013 and marky and
Getting stern right
Hollowed the stern to fit double control arm on rudder.
Installed 3=1 geared motor.
Did a water test in laundry test and hull is water tight.
Aimé par MouldBuilder and Martin555 and
Getting stern right
Hi Ron,
I can only agree with Martin and say what a great job you are doing. She will be a real credit to you when finished.
Nerys
Aimé par Martin555
Getting stern right
Hi Ron,
You are doing a great job.
I think she will be a really nice looking Tug when she is finished.
Aimé par Ronald
Getting stern right
Hull is fibreglassed and will be primed tomorrow. Paper gives an idea of above deck structure. Happy with how the project is coming along.
Aimé par mturpin013 and MouldBuilder and
Getting stern right
That is definitely taking shape now Ron.
Getting stern right
Redid the stern using balsa 1/4” sheet sections glued together. Removed earlier parts and now it is looking better.
Aimé par jbkiwi and RNinMunich and
Getting stern right
I started doing that last night. The top of the Bulkheads will be addressed after the hull sides are done.
Aimé par redpmg and Martin555
Getting stern right
For what its worth Ron it looks like the very top of the hull is a rounded section formed by the top plating tapering to a VERY narrow section at the stern (about 2/3 of what you have now) . The deck coaming is VERY slightly tilted forward at the stern which conforms to normal practice. It seems like the second plating forms two centered inverted V's on the chines at the stern . (Which agrees with your thinking about the two welded joints.)
As Martin says if you fill up the stern with blocks you should be able to sand/plane to the right sections.
Aimé par Ronald and Martin555
Getting stern right
Hi Ron, sorry I wasn't able to help you.
Aimé par Martin555
Getting stern right
Yes I have googled it and know that it had a former history as a Tugboat in the province of P.E.I. The owner sent me this, “ Her original name was Enmore built by Belmar welding of St,Catherines in 1959. She was owned by Dept Of Public Works until sold under the name TA2. transportation asset 2?”
I could not find any information about the tugboat, but hopefully someone will come back to me with something they have found.
Aimé par Martin555 and figtree7nts and
Getting stern right
Hi Ron, have you googled her name, it comes up with all 3 guises of the Miss Katherine.tug, prior to her being named that.
Maybe some pictures of her in navy form that might help.
Aimé par Martin555
Getting stern right
Its looking pretty good to me Ron ,if you trace the original photo (1) and place it over photo(7) you should be able to see where need to take off or add on.
Cheers Marky
Aimé par Martin555
Getting stern right
Ron,
It's a shame about the owner, but looking at what you have done up until now you will not be far off.
And if it is a little different then it will not matter.
All you need to do is get it to the standard that you want it to be.
Aimé par Ronald
Getting stern right
The photos are all I have and they are rather dark. I have asked the owner for some clearer pictures but am not getting much cooperation. 🥴
Aimé par Martin555
Getting stern right
Yes, I am thinking the same way. The final outcome should show the distinct welded seams, not a rounded hull.
Aimé par Martin555
Getting stern right
Hi Ron,
You are doing a great job, don't put you'r self down.
it is coming along nicely.
Maybe you could glue layers of Balsa wood to the stern and then slowly sand away what you don't need.
Aimé par Nerys
Getting stern right
Sorry for previous post, hadn't looked at all your photos. Presumably you are building a model of the tug in the photo. I don't think you are far out, but if you had more planks going up to the counter you would lose the rather hard chine effect and have a rounder, smoother look.
Nerys
Aimé par Martin555
Getting stern right
It's not really clear what sort of stern you are trying to create and on what sort of boat. More details please.
Aimé par Martin555
Getting stern right
I am in the process of stern building.
The photos are not clear enough to provide me the details I wish to see, nor is my model building experience to create what is needed.
Aimé par redpmg and marky and
