HI guys,
how big are ur rudders???
I love it when u get a brand new packaged rudder and release it from its box, it realy sends a tingle down my back!!!!!!!
HI guys,
HI Tallpaul
the prop I've fitted is 44mm , 4 blade brass , running on 7.2v she raises out of the water a treat .
You can get them from the following Email address......
Turn around is 2=3 days
Be lucky
Regards Bob J
*Email Address removed and sent by PM instead to Tall Paul.
HI Tallpaul
Be lucky
Regards Bob J
He left friday
only 7.2 v and planing ?
I'm trying a larger motor 900 and 12 V and it is not planing - I must be doing something wrong
Prop is a two bladed 50 mm dia - do you think I should be fitting a three balded one ?
Tall Paul
Tall Paul
Tall Paul.
Romsey, Hampshire.
HI , sorry for not getting back , work commitments.
I don't know wether it will come out but I have a photo of present set up..
just in case if it does not , I'll post a copy in my photo album...
Thanx for your assistance
Bob J
Bob J
He left friday
Have you got a picture of your present set up ? another member had the opposite with his 34" boat it tried to turn in side out, I also had a similar problem as you with my 34" boat it would not turn at speed, I moved the rudder forward towards the prop and it sorted it out.
peter
peter
hI , has any one got Info on size / shape of rudder for 48inch fireboat running single 700 elec. motor on 7.2 volts
She planes well but Is very reluctant to turn fast..
Cheers bob j
Cheers bob j
