Advice please on power train for 34" fireboat
Commencé par nzbruin
1 répy 0 aimers 0 abonnés Dernière activité : il y a 14 ans
HI Tony, there are many combinations out there, here is my current setup for my 34", its tried and tested, fast, go on hobbyking site, grab a turnigy T600 800kv outrunner, approx £25ish, turnigy reversing esc, 60 amp one, £35ish, and run on 4 lipo cells, 3 would be ok, two isnt enough volts for fast, if two cells was acceptable speed wise, then you might aswell go for a cheaper brushed set up with what you have, hope that helps, Paul
Hello All
In the 1960s, my brother built an Aerokits 34" fireboat. It was originally powered by an OS30 marine engine. He lost Interest In the project and I took It over In the early 1980s. The OS30 was persuaded to come to life and we had one glorious run on a nearby lake but the engine was on Its last legs. I then replaced It with an OS40 4-stroke marine but this was clearly too much power and the boat rolled badly with the torque. Again, the boat went Into storage. Last year, I got It out again and stripped all the Internal combustion engine stuff (fuel tank, silencer etc)out of It and temporarily Installed a Graupner Speed 700 electric motor I acquired cheaply. Using 3 LiFEPO4 cells (9.6V), It runs extremely well. I now want to finish the boat off (the fittings were never attached).
Although the boat performs well with the Speed 700, It Is very noisy and draws a lot of current (I have watercooled the motor and ESC). I would like to switch to a brushless motor. I would also like to run the boat on 2 cell LiPo packs. Can anyone advise a suitable motor and propellor combination to suit the boat and 7.4V power?
Thanks.
Tony
Christchurch
New Zealand
