Lesro Pilot power
Lesro Pilot power
Some brush rock crawler motor specs:-
Voltage 7.2 and all rpm's unloaded.
35 Turn 13,000
45 Turn 9,500
55 Turn 7,700
65 Turn 5,500
If you divide the voltage by rpm, you will get a brushless KV rating.
e.g. 5,500 divided by 7.2 equals about 750KV.
Props (Raboesch)
Type D :- 35mm max rpm 10,000
40mm max rpm 8,800
45mm max rpm 7,800
50mm max rpm 7,000
55mm max rpm 6,400
60mm max rpm 5,800
ESC I use the Hobbywing Quicrun 60 Amp for 2-3S lipo.
These have link set up for Lipo and NIMH batteries.
The other link is for Foward/Brake/Reverse.
On boats set to Forward/ Reverse.
This is the only ESC I found that goes straight from Forward into Reverse !!!!
Canabus
Lesro Pilot power
Lesro Pilot power
I have three Eileen/Hellen fishing boats running 540 Rock Crawler 80 turn brush motors on 7.2 volt Lipo batteries turn a 60mm 3blade prop.
I have trimmed to throttle back to 60% because the boats were over speed !!!
The motors run with no cooling .
Canabus
Lesro Pilot power
Lesro Pilot power
Lesro Pilot power
All motors make a noise but once the water the sound goes down. An MFA 800 is a big moter I have an MFA850 in my Sea Queen which is 46". Best way remove red gearboc cover just pulls off and spray with white lithium grease quitens it down 👍👍👍
Lesro Pilot power
The MFA Motor Data Table shows the 950D2.51 at 2329 rpm on 6 volts (unloaded) and the 950D61 at 1941 rpm on 12 volts and 971 rpm on 6 volts.
The motor in all cases with the MFA range use a standard RE-385 brush motor rated at 11646 rpm at 12 volts(unloaded). Both would easily turn that prop.
Canabus
Lesro Pilot power
Pilot boats are supposed to be slow I would use a brushed set up.
Lesro Pilot power
Having decided to build the Lesro Pilot i thought about power for it. I want a high torque setup so i can run an increased prop size and or prop pitch blade count. Lesro recommend a standard brushless setup with a 40mm 2 blade prop. I just found in my loft of goodies a Xerun V10 8.5T sensored brushless motor ( 2 pole ) with matching ESC ( quite an expensive setup intended for 1/10 RC buggies ) this motor is rated as 3940Kv with a mximum of 2s lipo. I like the thought of a sensored brushless setup for smooth startup but really not sure about this type of motors suitability, maybe running into a reduction gearbox ? MFA do a nice brushed 540 motor with 6:1 reduction gearbox attached which might be better but as i have the other kit if its suitable it would be good.
Aimé par
Chargement…
