Re: Elke HF408 kit
Commencé par gogetemfloyd
22 répies 30 aimers Dernière activité : il y a 6 ans
Hi doug, here are my two main querys which will hopefully put this matter to rest. Firstly, my battery is a turnigy 2200mah 3s 20 11.1v 20c- 30c burst lipo xt60.
I have a turnigy 12v basic lipo balance charger for 2s- 3s battery.
Now the confusion lies in this 'storage charge' , so if i charge it up and don't use it within a few days, apparently, i need to dicharge it to a certain voltage in order to store it , so what device must i get in order to accomplish this, or should i buy a better type of charger?. Secondly, given the type of battery and esc that i have, what voltage motor will be compatible. Thanks, floyd.
Aimé par Martin555
Hi Floyd,
You've received several replies giving useful advice in bits and pieces, some without providing the 'Why'!
So let me try to pull this altogether!😉
First:
The Elke is a Fish Cutter, very similar to my Billing Boats Danish North Sea fish cutter Gina 2.
They were 'plodders', max 10 knots at an educated guess. So you won't need a mighty meaty motor or lots of volts to drive it.
The original Graupner instructions recommend a 280 type brushed motor.
More than adequate for scale speed for a fish cutter. I'm assuming that the prop is approx 30mm diameter like my Gina 2 cutter. Which incidentally I propose to propel with a 50s vintage Taycol Target motor.
BUT: You say that you have already purchased a Quicrun ESC.
So your choice of motor is now defined by the type of that ESC.
As Rowen says the Quicrun range includes both brushed and brushless types.
Due to differences in the control technology of brushed and brushless motors you can not mix the types. I.E. brushed motor with brushless ESC or vice versa!
A brushed motor is simply DC driven. Connect a battery and it runs. 😀
A brushless motor is in essence a type of 3-phase AC motor and requires a corresponding electronic speed controller (ESC) to run it.
So which Quicrun ESC have you bought?
Battery:
Can appreciate your trepidation re LiPos as a newcomer to the technology.
Like Rowen I have had no problems with them for 4 years now.
But I have nearly 50 years of electronics engineering behind me so perhaps my perspective differs a bit from that of a novice!😉
By all means stick to NiMh if you are happier with that - model boating should be fun not worrying! But remember; ANY battery type can bite you if you maltreat it.
Even a so called 'Sealed' Lead Acid produces hydrogen gas when charging and vents it if the internal pressure gets too high through charging too long at high current!! So put yer fags out!😉 And buy a decent charger capable of charging AND monitoring NiMh. LiPo and SLA batteries. Cheaper than buying chargers for all three types 😀
BTW: A motor (brushed or brushless) does not care what type of battery you use 😊
All it wants is enough current at the right volts, so that can come from an NiMh, a LiPo, an SLA lead accumulator, or even silver oxide cells if you've just won the lottery 😁
So motor and battery can not be incompatible.😉 But motor and speed controller (ESC) CAN be!!🤔
Motor and ESC:
As said, motor choice will depend on the type of Quicrun ESC you have bought!
I hope that it was one of the brushed motor types; e.g. 1060.
A fish cutter does not need a powerful high revving or high torque brushless motor for reasons stated above.
If you have bought one of the Quicrun xxBLyy types of brushless ESC I suggest you save that for a later project, perhaps a fast MTB or PTB, or sell it and purchase a simple brushed ESC, e.g.Mtroniks Viper Marine 10. Or the Quicrun 1060.
RC kit: Transmitter & Receiver set (TX/RX).
I see that you have a 6 channel FlySky set 👍
Don't know it personally but it has similarities with my Turnigy set and several MB site members use variants of FlySky kit so you should be OK for set up / operating help if needed.
6 channels gives you scope for special functions like lighting etc etc.
But that's further down the line 😉 We can help with that when you get that far 👍
Hope this helps clarify things a little.
BTW: A few pics, or even make and type numbers, of what kit and equipment you have are always helpful to us when we are asked for advice re 'The Way Forward'.
The only daft question is the one that you are afraid to ask!😉
This site is full of bin there done that, 'this works fine' or 'tried this, won't do it again because ...' members and hundreds of years of experience! Use it 👍
Aimé par Martin555
Re Batteries Floyd,
Preeeee-ciseley Rowen👍, same with me, also 4 years or so.
Follow the rules and LiPos are no problem.
I also never charge at more than 1Amp.
The manufacturers only claim that they can be quick charged at 10 or 20Amps or whatever so that you do that, ruin the battery - reduce it's capacity and have to buy new ones.
Good for business🙄 But not for us!😠
I never charge NIMhs at more than 1A either.
When cycling (discharge/charge) to rejuvenate batteries, either NiMh or LiPo, I discharge at 5A and charge at 1A.
Aimé par Martin555 and Rowen
Been using LiPos for about 4 years and have standardized my fleet on them.
They have the best current density of all cells and seem to work well. The weight of lead-acid cells is too much for the smaller, faster electric models anyway.
So, if you are going to venture into the more "advanced" battery world, might as well go the whole hog.
Have heard stories of fires and other mishaps. I follow the charging and storage recommendations religiously and so far have never been concerned.
Usually charge at a max. rate of 1 A or lower, which is way under the max allowable. Always use a bag or steel ammunition box and never leave unattended.
So far, have worked for me.🤞
Aimé par Martin555 and RNinMunich
Yeah, i've built plastic kits on and off for 60yrs, i recently built the 1/72 flower class corvette (revell). It's the just the rc side of things thats got me stumped at the mo., . I'm going to put my query about lipo's to all and sundry and hope someone can ease my angst. As you probably guessed, i'm building the elke408, my plan is to convert it to a kriegsfischkutter, i got lucky, i joined the forum to try and get the plans and' roycv 'had the kit to sell, so here i am, worrying about batteries. C'est la vie. cheers , floyd.
Aimé par Martin555
Hi Floyd,
71 years old, Ah you're never to young to start 😀.
No problem, anything I can help you with just shout, if I don't know the answer someone else will.
The boat I'm building at the moment is an H A Kits morston (the small one) and even though I had a lot of various bits I still had to go shopping for an esc, batteries, propshafts etc 😀, Just reading through the various build blogs here gives you a good idea of what bits to get and where to get them.
With the Morston, space is very limited so I'm using Nimh battery packs for the main power and receiver, I've just ordered these from the component shop, they're pretty reasonable pricewise and they have a good selection.
The guys on here are very helpful, especially to newcomers to the hobby, and willing to answer any questions you might have.
Bill
Aimé par gogetemfloyd and Martin555
Thanks Bill, yeah, at the risk of spending a bit more than i expected, i'm thinking of getti g a nimh battery and charger. I'm 71 y.o. this month and time is more pre ious than money. I'll see what my local rc bloke has to say first, but i'm pretty much resigned to having to spend, i'll be able to get back to the build then. Thanks for the link, i'll give it a viewing shortly. Cheers .floyd.
Aimé par billmcl61 and Martin555
Hi Floyd,
I know how you feel, I'm on my first boat as well, any knowledge that I have has been gleaned from the good folks on this site.
As for Lipo batteries, I personally feel the same as you do, with my limited knowledge I'm sticking to Nimh or lead acid batteries for now.
However, I came across this article on the component shop website last night which might give you some helpful advice.
Bill
Recall that Quicrun make both brushed and brushless ESCs. You will need a motor of the same style.
The easy way to check is are there two or three motor wires? Two is brushed and three brushless.
Aimé par RNinMunich and Martin555
Hi bill, yes i've been deliberating on that. I've been looking into batteries recently and I'm a bit disenchanted with lipo batteries, they're akin to owning a petulant hand grenade, they'll apparently blow up or burn my house down, or just refuse to charge up, as a complete novice, i guess i was always going to make expensive bunders. It has'nt helped with my local rc shop being closed due to the covid, all the same, thanks a mil for your input and i'm totally open to advice from you guys with the knowledge. Thanks. floyd.
Aimé par Martin555
Hi Floyd,
If your motor and battery aren't compatible, it might be worth changing your motor instead of your battery, that would be much cheaper.
Bill
Hi Floyd,
Glad to help.
If you have anymore questions don't hesitate to ask.
Looking forward to seeing the build log.
Congratulations on your promotion to Able Seaman.
Yeah, thats what i thought. It looks like i might have to get a 6volt battery, i'm lucky enough to have a rc shop near me that should be up and running as normal from monday on, so i'll nip in there and see what advice i can get. Thanks a all for your help. floyd.
Aimé par Martin555
Hi Floyd,
If the motor is 6 to 12 Volts then you should be able to use the 11.1 volt Lipo.
If the motor is just 6 volt and you use the 11.1 volt battery then when you throttle up to full power you will burn out the motor.
I am by no means an expert on this subject but i am sure that other members could help you out.
Hi martin, ok, i found it, just need to find one with a mounting bracket. My next worry is ,it's 6volts, will my 11.1 volt lipo be ok with it, ? . My understanding is that the esc., reduces the voltage going to the motor. Thanks . floyd.
Aimé par Martin555
Hi, yes, i've got no knowledge of rc at all. I ended up looking on 'youtube' it's a minefield on google. Anyhow, i bought a flysky 2.4 fs- ct6b 6 channel, a hobby wing quicrun esc, a futaba servo and a turnigy 2200mah 3s 11.1 volt battery. The only thing that i need now,( i think), is a suitable motor, and i hav'nt a clue which one i need. Thanks .floyd.
Aimé par Martin555
Great to see you back Martin.
It is really unusual to have no replies. I am sure it just slipped under the RADAR.
Martin is a superb researcher so I think he will give you some valuable help and pointers.
Peter.
Aimé par Martin555
Hi Floyd,
I am very surprised that you have not had any response to your question.
Must of slipped through the gaps.
I will have to do a bit of research on the model you are working on before i could help.
Is there anything written in the instructions.
Aimé par MouldBuilder
Re: Elke HF408 kit
Hi, can anyone supply me with a concise list of all components that i need to rc my graupner ELKE .thanks, floyd.
Aimé par MouldBuilder and billmcl61 and
