RAF Crash Tender - Fire monitor - handle attachment
Abonnés (3)
- mturpin013Bronze
Can't beat genuine Araldite! The longer the setting time the better strength
Good Luck
Ian
It may stick but it will always be a very weak joint and prone to breaking with the slightest knock.
If that doesn't work how about filing off the lugs to increase the glueing area, putting a very short 90 degree bend on the end of the brass wire to go into a drilled hole to make a secure mechanical fixing and then applying the Araldite to fix it in place.
You could then build up the Araldite to re-make the shape of the lug that you filed off.
Rob.
Perhaps its worth contacting SLEC?
Peter
The SLEC fittings are die cast white metal so you can't solder brass to them and you definitely need to make a mechanical fixing rather than a chemical fixing (glue) for the handles.
It looks like there are some lugs cast into each side of the fitting into which you could possibly drill a 1.5mm hole to take the brass rod ends?
Rob.
Are you referring to the two arms that extend out from either side of the top nozzle piece with a cross piece that forms the operators handles? (see pic)
Rob.
PS they are made of white metal
Has anyone had a successful method to join these two parts ?
Peter
Aimé par
Chargement…
