yep 120a
Abonnés (3)
yep 120a
yep 120a
yep 120a
Yes of course I am well aware of such tricks.
Most of the early ESCs depended on relays for reversing anyway, until Darlingtons and then high Amp low R FETs came along.
But I didn't want to complicate things for the Red Baron.
He was trying to do it with an ESC and programming card which simply don't allow it🤔
yep 120a
Will probably use both switches to reverse 30amp brushless motors myself
They were dismantled to find gears for the Elvers vane steering.................... The motors are high drain so not much use but the 4.8v Nicads are fine after charging with a proper charger.........
And Doug the most famous for flying backwards in a headwind is the Piper or Taylor Cub fitted with a 65hp Lycoming twin - seen it myself having to be held down on the runway ............
yep 120a
Bad news I'm afraid😐
The short answer is 'You can't do it' ☹️
The YEP range of ESCs are for aircraft, which don't often fly backwards (except perhaps Tiger Moths in a headwind!🤔)
I've pored over the ESC and Programming Card manuals (see attachments) and there is absolutely NO mention of or allowance for a reverse running mode.
Afraid you're gonna have to buy a boat or car/truck ESC which has a reverse mode and motor to match with a decent kV rating (= 1000rpm per volt) at a reasonable voltage e.g. 6 to 12V.
Maybe you can flog that aircraft kit to a flyboy modeller?
I see that there are a few SK3 types which might be suitable for a ship model, which one do you have? What is it's kV rating?
To help you choose a suitable battery, motor and ESC combo for your boat please tell us what your boat/ship is; how big (total hull length and width) and weight without motors and battery. Sorry for the bad news. Next time; 'Taste and try - before you buy'! 😉
https://hobbyking.com/en_us/yep-120a-lv-2-6s-brushless-speed-controller-with-selectable-sbec.html?queryID=&objectID=40131&indexName=hbk_live_magento_en_us_products
https://hobbyking.com/en_us/yep-esc-programming-card.html
https://hobbyking.com/en_us/power-systems/electric-motors/brushless-motors.html#q=SK&idx=hbk_live_magento_en_us_products&dFR%5Bwarehouses%5D%5B0%5D=UK&dFR%5Bwarehouses_stock_data%5D%5B0%5D=UK%7C1&dFR%5Bwarehouses_stock_data%5D%5B1%5D=UK%7C2&dFR%5Bwarehouses_stock_data%5D%5B2%5D=UK%7C3&dFR%5Bwarehouses_stock_data%5D%5B3%5D=Global%7C1&dFR%5Bwarehouses_stock_data%5D%5B4%5D=Global%7C2&dFR%5Bwarehouses_stock_data%5D%5B5%5D=Global%7C3&dFR%5Bwarehouses_stock_data%5D%5B6%5D=EU%7C1&dFR%5Bwarehouses_stock_data%5D%5B7%5D=EU%7C2&dFR%5Bwarehouses_stock_data%5D%5B8%5D=EU%7C3&hFR%5Bcategories.level0%5D%5B0%5D=Power%20Systems%20%2F%2F%2F%20Electric%20Motors%20%2F%2F%2F%20Brushless%20Motors&is_v=1
Aimé par
Chargement…
