FPV Experience
FPV Experience
FPV Experience
I'm sure there are more of you who would like to be able to reasonably purchase a SYSTEM that would essentially be "plug and play" so you can "look out the pilot house" in real time as well as record the scenes.
This is why I started this post hoping that someone has "been there and done that".
Thanks Rod and Barry for your inputs.
Florida 😎, USA 🇺🇸
FPV Experience
I would suggest you go here to glean some good information on FPV.
https://www.rcgroups.com/aircraft-electric-fpv-861/
Barry
FPV Experience
FPV Experience
For a while a small group was coming to the pond we use. They were running high speed racing boats, too much speed for a 100m diameter pond. He had a Springer rescue boat set up with what I am looking for. He could watch his monitor attached to his rc transmitter where the View was from the pilot house.
However, they no longer come to the pond, probably because of the size.
Florida ⛱️, USA 🇺🇸
FPV Experience
FPV Experience
I've made several videos of model boats with the cameras mounted on board the boat at various positions. Some go back over ten years ago. Some involve using a servo to move the camera. All of this type of video requires editing to eliminate the unwanted parts resulting from continuous recording.
But now I would like to use FPV (first person video) to not only see what the camera is seeing, but record as well. I am looking for someone who has EXPERIENCE in this area. I would like to get a FPV SYSTEM that will do this at a decent resolution at a reasonable cost.
I say system because I don't want to sped my time figuring out what viewer, what camera, what power supply and battery, what transmitter, and what antenna. Ideally, would be a system that includes everything. However, if one of you has already put together something like this and can list all the items that when installed, it works.
I've seen some video cameras that look like a miniature 35mm SLR. Small size is optimal, especially for (temporarily) installing it for the pilots point of view.
Anyone gone there? How about multiple cameras?
Florida 😎, USA❤️
Aimé par
Chargement…
